Setting temperature boundary conditions for Convective heat transfer
Old   January 12, 2017, 04:49
Default Setting temperature boundary conditions for Convective heat transfer
Ma sir
huadian001 is on a distinguished road
Hello Foamers,
I have got a problem with the temperature boundary condition settings.First of all, i use OpenFoam 4.0.1 and the solver is chtmultiRegionfoam.I operate according to the case from https://foamingtime2.wordpress.com/s...eneration/,but he uses third-party software swak4foam.Now it does not support the current version OpenFOAM 4.0.1.
So,Who can help me convert groovyBC format to OpenFOAM format.
convectionWater
type groovyBC;
value uniform 200;
valueExpression "Twater";
gradientExpression "0";
fractionExpression "1.0/(1.0 + k/(mag(delta())*hc))";
variables
"hc=50.0;"
"Twater=20.0;"
"k=0.5;"
huadian001 is offline   Reply With Quote
Old   January 12, 2017, 04:56
floquation's Avatar
Kevin van As
floquation will become famous soon enough
swak4foam does work with OF4.0 if you manually apply a patch.
floquation is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Radiation interface hinca CFX 15 January 26, 2014 18:11
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
