i am facing this error while running elbow tutorial! |
January 9, 2017, 01:45 |
Aditya Patil
Rep Power: 9 |
Aadhi@Aditya /cygdrive/c/OpenFOAM/Aadhi-3.0.x/run
$ fluentMeshToFoam.exe elbow.msh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | |*---------------------------------------------------------------------------*| |* OpenFOAM for Windows 16.06 (v1) *| |* Built by CFD Support, www.cfdsupport.com (based on Symscape). *| \*---------------------------------------------------------------------------*/ Build : 3.0.x-ac3f6c67e02f Exec : C:\OpenFOAM\cygwin64\opt\OpenFOAM\OpenFOAM-3.0.x\platforms\cygwin64mingw-w64DPInt32Opt\bin\fluentMeshToFoam.exe elbow.msh Date : Jan 09 2017 Time : 06:42:39 Host : "ADITYA" PID : 2624 Case : C:/OpenFOAM/Aadhi-3.0.x/run nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: cannot find file file: C:/OpenFOAM/Aadhi-3.0.x/run/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting |
January 9, 2017, 02:09 |
Rep Power: 11 |
Looks like you did not enter your case directory of the elbow tutorial or forgot to copy it.
January 9, 2017, 02:18 |
#3 | |
Aditya Patil
Rep Power: 9 |
But i had copied it, still i am getting the same results, earlier it worked. I don't know why its not working now. you can see it below Aadhi@Aditya /cygdrive/c/OpenFOAM/Aadhi-3.0.x/run $ OpenWith.exe OpenFOAM-3.0.x/tutorials/incompressible/icoFoam/elbow_tri Aadhi@Aditya /cygdrive/c/OpenFOAM/Aadhi-3.0.x/run $ fluentMeshToFoam.exe elbow.msh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | |*---------------------------------------------------------------------------*| |* OpenFOAM for Windows 16.06 (v1) *| |* Built by CFD Support, www.cfdsupport.com (based on Symscape). *| \*---------------------------------------------------------------------------*/ Build : 3.0.x-ac3f6c67e02f Exec : C:\OpenFOAM\cygwin64\opt\OpenFOAM\OpenFOAM-3.0.x\platforms\cygwin64ming w-w64DPInt32Opt\bin\fluentMeshToFoam.exe elbow.msh Date : Jan 09 2017 Time : 07:21:33 Host : "ADITYA" PID : 3720 Case : C:/OpenFOAM/Aadhi-3.0.x/run nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMas ter allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: cannot find file file: C:/OpenFOAM/Aadhi-3.0.x/run/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting Aadhi@Aditya /cygdrive/c/OpenFOAM/Aadhi-3.0.x/run Last edited by Aditya Patil; January 9, 2017 at 02:23. Reason: Incomplete thread earlier |
January 9, 2017, 04:36 |
Rep Power: 11 |
I think you have to enter your case directory. From the error message above I guess you are in the directory:
HTML Code:
Aadhi@Aditya /cygdrive/c/OpenFOAM/Aadhi-3.0.x/run HTML Code:
Aadhi@Aditya /cygdrive/c/OpenFOAM/Aadhi-3.0.x/run/elbow_tri |
January 9, 2017, 06:01 |
Aditya Patil
Rep Power: 9 |
Ok thanks a lot. i will try again.
OpenFOAM parallel on VM? pimpleDyMFoam propeller tutorial has been running for hours. | MBttR | OpenFOAM Running, Solving & CFD | 0 | June 13, 2016 10:58 |
Suse10 FoamX problem | frank178 | OpenFOAM Installation | 6 | January 14, 2010 04:18 |
Compilation Error when running Tutorial 2.4 | zhihuali | Siemens | 7 | April 1, 2008 07:34 |
Running Tutorial Eulerian Granular Heat file | Femi | FLUENT | 0 | March 8, 2007 12:01 |
Tutorial is not running on star-CD version 3.2 | Arnab | Siemens | 0 | August 30, 2004 15:43 |
