Getting chtMultiRegionFoam - Case running
Old   January 5, 2017, 13:44
Default Getting chtMultiRegionFoam - Case running
Deutschland
Perschr is on a distinguished road
Hey everybody,
I'm about to get a free convention around a lamp running and I am stuck, as my case shows some weird behaviour.
My case runs till 10 seconds, then it breaks up, however I don't know why.
1. problem
After running til 10 seconds the case cannot be opened with the command paraFoam. --> see errormessage in the picture. What is the problem here?
2. At the inlet at the bottom I have temperatures of 310 K, however I have a fixedValue boundary of 300K?!? How can that happen?
3. I cannot detect any conjugated heat transfer, not even in the component diode, which is with a Temperatur-boundary of 500K applied. This is pretty uncommon after 10 seconds.
Does someone has Input for me?Thanks!
boundary for the surrounded air:
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0/domain0";
object T;
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * //dimensions [ 0 0 0 1 0 0 0 ];
internalField uniform 300;
boundaryField
maxY
type zeroGradient;
minX
type fixedValue;
value uniform 300;
maxX
type inletOutlet;
value uniform 300;
inletValue uniform 300;
minY
type zeroGradient;
minZ
type symmetryPlane;
maxZ
type zeroGradient;
value uniform 300;
domain0_to_lampe
type compressible::turbulentTemperatureCoupledBaffleMix ed;
value uniform 300;
Tnbr T;
kappaMethod fluidThermo;
domain0_to_schirm
value uniform 300;
Tnbr T;
domain0_to_kuehlrippen
value uniform 300;
Tnbr T;
domain0_to_schirmhalter
value uniform 300;
Tnbr T;
domain0_to_leuchtenhalter
value uniform 300;
Tnbr T;
U-File of the surrounded air:
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * //dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform ( 0 0 0 );
boundaryField
maxY
type zeroGradient;
value uniform ( 0 0 0 );
minX
type pressureInletVelocity;
maxX
type pressureInletOutletVelocity;
inletValue uniform ( 0 0 0 );
minY
type zeroGradient;
minZ
type symmetryPlane;
maxZ
type zeroGradient;
domain0_to_lampe
type fixedValue;
domain0_to_schirm
type fixedValue;
type fixedValue;
type fixedValue;
type fixedValue;
boundary of the component diode:
FoamFile
version 2.0;
format ascii;
location "0/diode";
object T;
boundaryField
minZ
type fixedValue;
value uniform 500;
diode_to_lampe
value uniform 300;
Tnbr T;
kappaMethod solidThermo;
diode_to_air2
value uniform 300;
Tnbr T;
File Type: jpg Bildschirmfoto vom 2016-12-28 19-15-00.jpg (161.4 KB, 11 views)
File Type: jpg Bildschirmfoto vom 2016-12-30 09-16-50.jpg (96.7 KB, 8 views)
File Type: jpg Bildschirmfoto vom 2016-12-30 09-20-13.jpg (90.8 KB, 9 views)
Perschr is offline   Reply With Quote
Problem running my case OF2.4 vs OF2.3.1 Zinedine OpenFOAM Running, Solving & CFD 2 March 15, 2016 05:56
Error in running case in chtMultiRegionFoam baran_foam OpenFOAM Programming & Development 3 July 7, 2015 05:38
chtMultiRegionFoam running in parallel sparbroetchen OpenFOAM Running, Solving & CFD 1 July 30, 2012 04:10
chtMultiRegionFoam case - temperature too high phsieh2005 OpenFOAM Running, Solving & CFD 0 April 24, 2010 09:53
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
