Scalar Transport over boundary
Old   January 4, 2017, 18:32
Lightbulb Scalar Transport over boundary
FlyBob91's Avatar
FlyBob91 is on a distinguished road
Hello to all,
I need to calculate the passive scalar in a duct after running a steady simulation to obtain the velocity field.
My geometry consists in a duct with two inlets and what i have to do is to calculate the concentration field of the fluids. For this reason, in the T boundary condition file, i put unitary value on the first inlet and a null value on the second inlet for T.
imensions      [0 0 0 1 0 0 0];
internalField   uniform 0;
boundaryField
    inlet1
        type            fixedValue;
        value           uniform 1;
    inlet2
        type            fixedValue;
        value           uniform 0;
    outlet
        type            zeroGradient;
    walls
        type            zeroGradient;
    mouvable
        type            zeroGradient;
After running the simulation i've found that T assumes, in some regions, values below to zero and over to one. Any idea about this problem?
The second doubt i have is about the fact that the first simulation to find the velocity field is unsteady, while i calculated the passive scalar with an unsteady simulation. Is this a correct procedure or i have to run an unsteady simulation also for the passive scalar?
Thanks for help
FlyBob91 is offline   Reply With Quote
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 22:16
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
