adjustTimeStep based on 'Film max Courant number' |
January 2, 2017, 05:12 |
Rep Power: 9 |
in the reactingParcelFilmFoam are two fluid regions: the WallFilm and the FlowField. Is there a possibility to change this in the controlDict Code:
... adjustTimeStep yes; maxCo 1; maxDeltaT 0.002; ... They are calculated seperatly and written into the log-file. So the values exist already.. Because of the implicit PIMPLE, it wouldn't be a problem if Co >1 in the Flowfield. For the WallFilm-Region Co<1 is important. If I could change this, it would speed up the Simulation quiet a lot... thanks for your help! |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
