Custom boundary by face
Old   December 28, 2016, 13:04
Smile Custom boundary by face
gironidegirona is on a distinguished road
Hi you all,
I'm trying to use openfoam as an interconnect for different processes and I'm interested on defining a boundary by face. I mean, I have the list of faces of a boundary but I would like to specify the value of the outlet flow of this boundary by face (I have mapped one model to the other so I know what it belongs to what).
Is it possible?
Thanks in advance!
gironidegirona is offline   Reply With Quote
Old   December 29, 2016, 09:05
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
If you are talking about boundary faces, you can use codedFixedValue.
Sent from my HTC One mini using CFD Online Forum mobile app
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   January 15, 2017, 09:18
Thank you Tobi, I maked that work for flow following this example: http://www.sourceflux.de/blog/the-co...ary-condition/
thanks! The thing is imagine I have a patch which is inlet and I want to have an alpha phase plus non-alpha phase on this face. I would like to create a region which is taking the same inlet speed of the whole patch but to be alpha inlet, and the rest non-alpha inlet. Is like the example provided before but with alpha and non-alpha inlet on the same boundary face, is it possible?
Thanks again!
Old   January 15, 2017, 10:01
Tobi's Avatar
Tobias Holzmann
Of course it is possible. There for you just have to get the face values of alpha and code (based on alpha) you inlet profile. Finally you can do whatever you would like to do.
Keep foaming,
Tobias Holzmann
Old   January 15, 2017, 13:19
Hey Tobi, thanks! I found out how to it, I was taking the code literally without thinking very much, what I did is on alpha.water (in my case).
redirectType basically is the name of the class I'm creating in my case "alphainRectangle" and as per proof of concept I'm taking the same strategy to set new values on a rectangle (in my case in a y-region inside the patch) and then modify the boundary according to what i need.
inlet
type codedFixedValue;
value uniform 0;
redirectType alphainRectangle;
code
const fvPatch& boundaryPatch = patch();
const vectorField& Cf = boundaryPatch.Cf();
scalarField& field = *this;
scalar min = 0.00065;
scalar max = 0.0008;
forAll(Cf, faceI)
if (
(Cf[faceI].x() > min) &&
(Cf[faceI].x() < max)
field[faceI] = 1;
Thanks again tobi!
I hope it'll help someone!
boundary, custom, face, mapping
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Radiation interface hinca CFX 15 January 26, 2014 18:11
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
