December 28, 2016, 06:16 |
Induction Motor in chtMultiRegionFoam
Xabi
Rep Power: 9 |
Hi Foamers,
I am trying to simulate the heating that occurs in an induction motor, alongside with the cooling of it with the help of an external fan. The induction motor looks like in the attached image (cut in half). The domain with the red color is the air and the rest are the different components of the motor like the stator and rotor. I exported the mesh with ideasUnvToFoam with the file exported from Salome, consisting of tetrahedra cells. The checkMesh log file looks like this. Code:
Mesh stats points: 312343 faces: 3585501 internal faces: 3550655 cells: 1784039 faces per cell: 4 boundary patches: 3 point zones: 0 face zones: 0 cell zones: 6 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 1784039 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 164 100 ok (non-closed singly connected) outlet 2629 1444 ok (non-closed singly connected) defaultFaces 32053 16174 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.2277233 -0.22612136 -0.35775) (0.2292767 0.23087864 0.38025) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (3.0428315e-017 3.5912087e-018 4.5874614e-017) OK. Max cell openness = 3.1519565e-016 OK. Max aspect ratio = 9.1970767 OK. Minimum face area = 1.1271098e-007. Maximum face area = 0.000228302. Face area magnitudes OK. Min volume = 1.8090004e-011. Max volume = 1.0056312e-006. Total volume = 0.091300385. Cell volumes OK. Mesh non-orthogonality Max: 68.406458 average: 17.469148 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.7404942 OK. Coupled point location match (average 0) OK. Mesh OK. End Code:
Time = 5 Solving for fluid region air smoothSolver: Solving for Ux, Initial residual = 0.21578625, Final residual = 0.010209813, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.26924827, Final residual = 0.01026977, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.14502202, Final residual = 0.0060408645, No Iterations 3 GAMG: Solving for h, Initial residual = 0.31451636, Final residual = 0.00035917851, No Iterations 1 Min/max T:299.97213 300.16361 GAMG: Solving for p_rgh, Initial residual = 0.020587446, Final residual = 0.00012616458, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 0.011918253, Final residual = 6.4418955e-005, No Iterations 2 time step continuity errors : sum local = 13.092179, global = 3.034886, cumulative = 4.7881806 Min/max rho:1.15857 42.31626 smoothSolver: Solving for epsilon, Initial residual = 0.45136702, Final residual = 0.01080506, No Iterations 4 smoothSolver: Solving for k, Initial residual = 0.28291767, Final residual = 0.0067125576, No Iterations 4 Solving for solid region carcasa smoothSolver: Solving for h, Initial residual = 0.062395741, Final residual = 6.6960944e-007, No Iterations 11 smoothSolver: Solving for h, Initial residual = 0.036724725, Final residual = 6.0332786e-007, No Iterations 11 smoothSolver: Solving for h, Initial residual = 0.027209336, Final residual = 5.284252e-007, No Iterations 11 smoothSolver: Solving for h, Initial residual = 0.021678707, Final residual = 4.7436983e-007, No Iterations 11 Min/max T:299.99999 300.04461 Solving for solid region estator smoothSolver: Solving for h, Initial residual = 0.055643605, Final residual = 6.6323807e-007, No Iterations 12 smoothSolver: Solving for h, Initial residual = 0.051877492, Final residual = 6.0780338e-007, No Iterations 12 smoothSolver: Solving for h, Initial residual = 0.043999489, Final residual = 5.6605775e-007, No Iterations 12 smoothSolver: Solving for h, Initial residual = 0.040695944, Final residual = 5.3075743e-007, No Iterations 12 Min/max T:300.00334 300.10069 Solving for solid region paquete smoothSolver: Solving for h, Initial residual = 0.058619361, Final residual = 6.8645591e-007, No Iterations 12 smoothSolver: Solving for h, Initial residual = 0.052623025, Final residual = 6.431375e-007, No Iterations 12 smoothSolver: Solving for h, Initial residual = 0.047983007, Final residual = 6.0354914e-007, No Iterations 12 smoothSolver: Solving for h, Initial residual = 0.044679787, Final residual = 5.6956311e-007, No Iterations 12 Min/max T:300.00166 300.20722 Solving for solid region rotor smoothSolver: Solving for h, Initial residual = 0.24895255, Final residual = 5.4206869e-007, No Iterations 14 smoothSolver: Solving for h, Initial residual = 0.23538873, Final residual = 5.1776333e-007, No Iterations 14 smoothSolver: Solving for h, Initial residual = 0.22339747, Final residual = 4.9532464e-007, No Iterations 14 smoothSolver: Solving for h, Initial residual = 0.21173401, Final residual = 4.7114533e-007, No Iterations 14 Min/max T:300.02767 300.12027 Solving for solid region eje smoothSolver: Solving for h, Initial residual = 0.053108372, Final residual = 7.7474521e-007, No Iterations 11 smoothSolver: Solving for h, Initial residual = 0.041939269, Final residual = 6.7947562e-007, No Iterations 11 smoothSolver: Solving for h, Initial residual = 0.034449824, Final residual = 5.984097e-007, No Iterations 11 smoothSolver: Solving for h, Initial residual = 0.029809757, Final residual = 5.4919018e-007, No Iterations 11 Min/max T:300 300.0472 ExecutionTime = 1551.259 s ClockTime = 1551 s Time = 6 Solving for fluid region air smoothSolver: Solving for Ux, Initial residual = 0.14536389, Final residual = 0.0028420734, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.1776137, Final residual = 0.0082670569, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.077735287, Final residual = 0.0021526489, No Iterations 3 GAMG: Solving for h, Initial residual = 0.27370362, Final residual = 0.00032454368, No Iterations 1 Min/max T:299.91886 300.20152 GAMG: Solving for p_rgh, Initial residual = 0.11728298, Final residual = 0.00097518063, No Iterations 7 GAMG: Solving for p_rgh, Initial residual = 0.011725349, Final residual = 9.0269481e-005, No Iterations 2 time step continuity errors : sum local = 48.434583, global = -0.69965801, cumulative = 4.0885226 Min/max rho:1.1584873 77.331698 smoothSolver: Solving for epsilon, Initial residual = 0.34649269, Final residual = 0.00827647, No Iterations 4 smoothSolver: Solving for k, Initial residual = 0.21215974, Final residual = 0.0048938131, No Iterations 4 Solving for solid region carcasa smoothSolver: Solving for h, Initial residual = 0.047114892, Final residual = 5.5770834e-007, No Iterations 11 smoothSolver: Solving for h, Initial residual = 0.029313556, Final residual = 5.1500126e-007, No Iterations 11 smoothSolver: Solving for h, Initial residual = 0.022470358, Final residual = 4.6051181e-007, No Iterations 11 smoothSolver: Solving for h, Initial residual = 0.018371939, Final residual = 4.1948118e-007, No Iterations 11 Min/max T:299.99998 300.05785 Solving for solid region estator smoothSolver: Solving for h, Initial residual = 0.046429597, Final residual = 5.400198e-007, No Iterations 12 smoothSolver: Solving for h, Initial residual = 0.044012641, Final residual = 5.0060242e-007, No Iterations 12 smoothSolver: Solving for h, Initial residual = 0.036691329, Final residual = 4.712569e-007, No Iterations 12 smoothSolver: Solving for h, Initial residual = 0.034245203, Final residual = 4.4579687e-007, No Iterations 12 Min/max T:300.00437 300.12382 Solving for solid region paquete smoothSolver: Solving for h, Initial residual = 0.048195464, Final residual = 5.6117088e-007, No Iterations 12 smoothSolver: Solving for h, Initial residual = 0.043632525, Final residual = 5.3137647e-007, No Iterations 12 smoothSolver: Solving for h, Initial residual = 0.040063593, Final residual = 5.0325471e-007, No Iterations 12 smoothSolver: Solving for h, Initial residual = 0.037600986, Final residual = 4.7882229e-007, No Iterations 12 Min/max T:300.00231 300.24237 Solving for solid region rotor smoothSolver: Solving for h, Initial residual = 0.20894768, Final residual = 4.5419299e-007, No Iterations 14 smoothSolver: Solving for h, Initial residual = 0.19869693, Final residual = 4.3668252e-007, No Iterations 14 smoothSolver: Solving for h, Initial residual = 0.18949435, Final residual = 4.2009112e-007, No Iterations 14 smoothSolver: Solving for h, Initial residual = 0.18073094, Final residual = 4.021397e-007, No Iterations 14 Min/max T:300.03535 300.14188 Solving for solid region eje smoothSolver: Solving for h, Initial residual = 0.043873939, Final residual = 6.6680866e-007, No Iterations 11 smoothSolver: Solving for h, Initial residual = 0.03563445, Final residual = 5.9662922e-007, No Iterations 11 smoothSolver: Solving for h, Initial residual = 0.029814852, Final residual = 5.3286034e-007, No Iterations 11 smoothSolver: Solving for h, Initial residual = 0.026125858, Final residual = 4.9347162e-007, No Iterations 11 Min/max T:300 300.05855 ExecutionTime = 1813.066 s ClockTime = 1813 s Time = 7 Solving for fluid region air smoothSolver: Solving for Ux, Initial residual = 0.17284958, Final residual = 0.007962946, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.19257908, Final residual = 0.0080746212, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.15193187, Final residual = 0.0068897998, No Iterations 3 GAMG: Solving for h, Initial residual = 0.15194215, Final residual = 0.00015001932, No Iterations 1 Min/max T:299.93498 300.23818 GAMG: Solving for p_rgh, Initial residual = 0.011104256, Final residual = nan, No Iterations 1000 GAMG: Solving for p_rgh, Initial residual = nan, Final residual = nan, No Iterations 1000 --> FOAM FATAL IO ERROR: wrong token type - expected Scalar, found on line 0 the word 'nan' file: C:/.../system/air/data.solverPerformance.p_rgh at line 0. From function operator>>(Istream&, Scalar&) in file lnInclude/Scalar.C at line 93. FOAM exiting Code:
solvers { rho { solver PCG; preconditioner DIC; tolerance 1e-05; relTol 0.01; } p_rgh { solver GAMG; smoother DICGaussSeidel; tolerance 1e-08; relTol 0.01 } "(U|k|epsilon|R)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0.05; } h { solver GAMG; smoother DILUGaussSeidel; tolerance 1e-07; relTol 0.01; } } SIMPLE { nNonOrthogonalCorrectors 1; residualControl { p_rgh 1e-6; U 1e-4; } pRefCell 0; pRefValue 0.0; } relaxationFactors { fields { rho 1; p_rgh 0.3; } equations { "h.*" 0.7; "U.*" 0.7; k 0.7; epsilon 0.7; } } // ************************************************************************* // Code:
ddtSchemes { default steadyState; } gradSchemes { default cellMDLimited Gauss linear 0.5; grad(U) cellMDLimited Gauss linear 0.5; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); div(phi,K) bounded Gauss linear; div(phi,h) bounded Gauss linearUpwind default ; div(phi,k) bounded Gauss linearUpwind default; div(phi,epsilon) bounded Gauss linearUpwind default; div(phi,R) Gauss linearUpwind default; div(R) Gauss linear; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss cubic limited 0.5; } interpolationSchemes { default linear; } snGradSchemes { default limited 0.5; } // ************************************************************************* // Does someone have an idea of how to solve the problem? How to decrease the time step continuity errors and the divergence of p_rgh? Thanks in advance Last edited by xsa; January 10, 2017 at 04:43. |
Error in thermophysical properties (chtMultiRegionFoam) | mukut | OpenFOAM Pre-Processing | 28 | November 23, 2021 06:34 |
Error in chtMultiRegionFoam | kirankarki | OpenFOAM | 6 | August 21, 2018 08:00 |
Simulation of a sample in a furnace w/ chtMultiRegionFoam | sergimart7 | OpenFOAM Running, Solving & CFD | 7 | August 12, 2015 06:48 |
is it possible to modelize induction heating in a frequency domain with OpenFOAM? | julien23 | OpenFOAM | 0 | January 12, 2015 05:47 |
FOAM FATAL IO ERROR for chtMultiRegionFoam | xiaoyoyo | OpenFOAM Running, Solving & CFD | 0 | May 8, 2012 16:49 |
