Cubic scheme and spurious oscillation in velocity. Any alternative? |
December 21, 2016, 01:32 |
Lorenzo
Rep Power: 10 |
Dear Collegues,
I'm currently facing undesired spurious oscillation in velocity solution in a DNS performed with cubic scheme (OF 4.0). Some images are attached. My question to you: according to your knowledge is this behaviour related to the Courant number ( and so to the timeStep ) or is it a matter of mesh resolution ( so a spatial resolution issue). Thank you for your attention and your help Some details: mesh grid size around 0.2 mm and fixed timeStep adopted is 1e-5s. Temporal scheme is implicit backward. Spatial discretization scheme is cubic (4th order). The same issue does not arise with linear scheme ( 2nd order) |
When to use upwind or central differencing schemes? | quarkz | Main CFD Forum | 6 | August 19, 2011 03:24 |
