Whoa hey.... sum of reacting species is greater than 1? |
December 16, 2016, 20:43 |
#1 | ||||
Anonymouse
Rep Power: 11 |
I've been trying to figure out why my reaction's been blowing up... and it looks like I just found something that's probably Very Bad(tm). I wrote a program to sum up all of the species in each block, and they're sometimes amounting to significantly more than 1. Shortly after I start, the highest block sum is 1.57. In my last timestep before the crash, the the highest is over 5 - some blocks with individual species over 4. I mean, just crazy-high.
Googling the problem I see one person advise (over a decade ago): Quote:
chemistry is EulerImplicit, cTauChem 1.0, equilibriumRateLimiter off. Any clue what could be wrong or what I could try? |
June 29, 2017, 12:28 |
Cloudy
Hi, I am just wondering if you have found out the reason and solved this issue eventually?
Thanks. |
June 29, 2017, 14:47 |
Anonymouse
Rep Power: 11 |
My experience has generally been that such problems, at least with reactingFoam, is that they're triggered by having one of your reactions improperly balanced. I think another cause can be if your species percents don't addup to 1. I may have encountered some other things that can generate this problem but I don't recall them.
September 28, 2024, 10:31 |
Ravi
Rep Power: 3 |
I know this is very late but maybe this will be useful to someone else who has the same problem. Often times when I get this error it is due to improper initialization in the 0 folder. If say you have initialized at the inlet that O2 is entering with a mass fraction of 0.232, then you should make sure the addition of all other species at the inlet + O2 at the inlet sum to 1. Ensure this for every patch and the internalField in your 0 folder. If this is not done, the solver will give nonphysical results.
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
