[swak4Foam][DyM] "Fatal Error: incorrect size" while regenerating sampledSurface |
December 13, 2016, 12:00 |
#1 | |
Kevin van As
Rep Power: 21 |
While regenerating a sampledSurface during the first dynamic mesh refinement (dynamicRefineFvMesh), I receive the following fatal error.
The solver is interDyMFoam, using a 3D uniform blockMesh. The OpenFoam version is 4.0. I should mention that the functionObject below does work for version 2.4.0. Fatal Error: Code:
PIMPLE: iteration 1 Selected 400 cells for refinement out of 65536. Refined from 65536 to 68336 cells. Forcing regeneration of surface awInterface --> FOAM FATAL ERROR: Incorrect size. mesh: nCells:68336 points:74235 cVals:65536 <-- pre-refinement #cells cCoords:68336 <-- post-refinement #cells snappedCc:68336 pVals:74235 pCoords:74235 snappedPoint:74235 From function void Foam::isoSurface::generateTriPoints(const volScalarField&, const scalarField&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::Field<Type>&, const Foam::DynamicList<T>&, const labelList&, const labelList&, Foam::DynamicList<T>&, Foam::DynamicList<int>&) const [with Type = Foam::Vector<double>; Foam::volScalarField = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>; Foam::scalarField = Foam::Field<double>; Foam::labelList = Foam::List<int>] in file sampledSurface/isoSurface/isoSurfaceTemplates.C at line 546. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 void Foam::isoSurface::generateTriPoints<Foam::Vector<double> >(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::Field<double> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::Field<Foam::Vector<double> > const&, Foam::DynamicList<Foam::Vector<double>, 0u, 2u, 1u> const&, Foam::List<int> const&, Foam::List<int> const&, Foam::DynamicList<Foam::Vector<double>, 0u, 2u, 1u>&, Foam::DynamicList<int, 0u, 2u, 1u>&) const at ??:? #3 Foam::isoSurface::isoSurface(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::Field<double> const&, double, bool, double) at ??:? #4 Foam::sampledIsoSurface::updateGeometry() const at ??:? #5 Foam::SurfacesRepository::updateSurface(Foam::word const&, Foam::fvMesh const&) at ??:? #6 Foam::createSampledSurface::redoSurface() at ??:? #7 Foam::functionObjectList::updateMesh(Foam::mapPolyMesh const&) at ??:? #8 Foam::polyMesh::updateMesh(Foam::mapPolyMesh const&) at ??:? #9 Foam::fvMesh::updateMesh(Foam::mapPolyMesh const&) at ??:? #10 Foam::dynamicRefineFvMesh::refine(Foam::List<int> const&) at ??:? #11 Foam::dynamicRefineFvMesh::update() at ??:? #12 ? at ??:? #13 __libc_start_main in "/lib64/libc.so.6" #14 ? at /usr/src/packages/BUILD/glibc-2.11.3/csu/../sysdeps/x86_64/elf/start.S:116 Aborted swak4Foam functionObject: A swak4Foam functionObject was used for generating the sampledSurface, but I don't think that is relevant for the error? I presume that the calculation of the sampledSurface is part of OpenFoam, and swak4Foam just calls the appropriate function? Code:
createInterface { type createSampledSurface; outputInterval 1; outputControl timeStep; surfaceName awInterface; surface { type isoSurface; isoField alpha.water; isoValue 0.5; interpolate true; } } A possible solution is to use "interpolate false;", but that doesn't work for my case: Code:
--> FOAM FATAL IO ERROR: Non-interpolated iso surface not supported since triangles span across cells. According to the swak4Foam ReadMe, this might be a known bug. However, the date on that document is 2012 and the functionObject does work in v2.4.0, so I'm not sure if this is the same thing. Besides, I have a dynamicRefineMesh, which is not really a moving mesh, is it? Quote:
Has anyone encountered this issue before? Is there any sort of solution known? Is there any reason in particular that it does work in v2.4.0, but not in v4.0? Thanks in advance. |
October 1, 2019, 13:08 |
#2 | |
Yuanwei Cao
Rep Power: 9 |
Have You solved it? Ia also met this problem. |
dynamicrefinefvmesh, fatal error, sampledsurface, swak4foam |
