Which solver to use for a compressible fluid and moving mesh |
I am trying to simulate a engine case to find the behaviour of the charge motion inside a cylinder during compression stroke. The fluid is compressile and it is a moving mesh. Now i am confused which solver to use, I checked online that rhoPimpleFoam is used for transient conditions but for HVAC applications. Is it possible to calculate my case with this solver or are there any other solvers best suitable for my case. Please leave me your comments. Thank You |
Oskar
Rep Power: 10 ![]() |
Hello Aravind Krish.
I'm not a specialist but I think You should try engineFoam. Unfortunately it doesn't include mesh topology change. I think engineFoam could deal with vertical valve in some simple configuration (flat piston and low CR). Probably there is engineDyMfoam in 1.6-ext. (I'm not sure) that include changing mesh topology. Some pdf I found during my previous research: http://powerlab.fsb.hr/ped/kturbo/Op...Zagreb2007.pdf http://kth.diva-portal.org/smash/get...689/FULLTEXT01 https://imem.cray.com/2013/Meeting-2...lia-Milano.pdf https://hpc-forge.cineca.it/files/Co...OAM-PoliMi.pdf Have a nice day. sheaker |
Thank you Sheaker will try with that
openfoam, rhopimplefoam, solvers |
Solver options for moving fluid boundaries | Stephen Waite | OpenFOAM Running, Solving & CFD | 2 | September 24, 2015 22:51 |
2D selective mesh generation | Durga Sravan | ANSYS | 17 | February 5, 2014 00:56 |
LES with moving mesh solver | gtg627e | OpenFOAM Running, Solving & CFD | 2 | July 23, 2007 10:40 |
Moving Mesh Problem in Unix Platform | Arnab | Siemens | 3 | August 16, 2004 08:59 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
