November 30, 2016, 17:16 |
Porous simpleFoam!
OpenFoam
Rep Power: 10 |
Hello Foamers,
I am new to openfoam and need to do a lot of simulations for my master's project. I would like to simulate the flow over a c-d nozzle with a specified load at the throat. All I know so far is the amount of thrust required at a given speed. The problem is that I don't know how to specify the load or where to start. I have found some case examples comes with the poroussimpleFoam but no clue how to specify the load on the mesh as well as a value of thrust coefficient Ct=0.2. I am hoping that someone might have done something similar could find sometime to help in this subject. Any help would be really appreciate it. Thanks in advance, |
December 1, 2016, 18:34 |
OpenFoam
Rep Power: 10 |
Any helps
December 2, 2016, 03:33 |
Nima Samkhaniani
Rep Power: 25 |
wrong approach
you are new to OpenFOAM, so try to spend time to learn general simulation stuff, such as: 1-mesh generation: you can use OpenFOAM mesh generator (blockMesh and snappyHexMesh) or you can import it from other mesh generator such as (gambit, salome, ICEM ,Ansys meshing and so on) 2-try to find your suitable solver. what kind of fluid you have? one phase or multiphase? newtonian or non-newtonian? heat transfer and combustion? compressible or incompressible? phase change? try to define what you are dealing with, so when you find the appropriate solver, you should study the existing tutorial and find how it works 3-now it is time to work on your test case so i suggest to start with OpenFOAM user guide and read at least first chapter to find how to run and play existing test cases in OpenFOAM
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
December 2, 2016, 13:32 |
#4 | |||
OpenFoam
Rep Power: 10 |
Hello Nimasam,
Thank you for your reply. I will try to answer your questions point by point; Quote:
December 3, 2016, 09:57 |
Nima Samkhaniani
Rep Power: 25 |
honestly i don't understand what you want to accomplish However, in order to prepare porous zone, you need to define a cell zone using toposet or from importing grid, then introduce this cell zone to porousPropertiesDict
December 4, 2016, 14:51 |
OpenFoam
Rep Power: 10 |
Would be possible to walk me through the process of setting the toposet if posted the grid?
November 8, 2022, 04:18 |
Melissa
Rep Power: 4 |
It's been a while but did you manage to do that ? Thank you in advance. |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 05:09 |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 05:10 |
How to Produce a Multiregion Porous Media - simpleFoam | DavidOuellette | OpenFOAM Running, Solving & CFD | 5 | March 6, 2013 18:23 |
Porous panel for airflow over a radiator with simpleFoam? | Doug68 | OpenFOAM Running, Solving & CFD | 0 | May 14, 2012 02:11 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 16:16 |
