Turbine simulation and turbulence parameters: Floating point exception issues |
November 30, 2016, 08:31 |
Dave
Rep Power: 10 |
Hi all,
I have been trying to validate my OpenFOAM methodology by modelling a 3-bladed water turbine and validating it against literature as found here. Ultimately I want to match recorded torque values over the blades through refinement of the boundary layer region, however at the moment I am just trying to get a simulation running. I have spent a long time trying to obtain a semi-reasonable mesh to solve using pimpleDynamicMeshFoam. I feel like my current mesh is good enough to get atleast something out. I've attached a screenshot and welcome your thoughts on this. I am solving using the k-omegaSST turbulence model, however I am little confused about the calculation of input parameters in the 0 folder. I have calculated the input variables nut, k, omega using the turbulence guidelines found here, and verified them through the calculator here. Velocity is taken from the aforementioned literature, p is set as zeroGradient. My simulation currently fails through the Courant number exploding, resulting in a floating point exception early in the simulation. Given that the Courant number is governed by u*t/x, in which freestream velocity and time step are stated in literature - this would initially lead me to believe the mesh is still the issue. However, Para View doesn't seem to offer any hints as to a location in the mesh that could be failing, so perhaps this is likely to result from my boundary conditions/input parameters? Is anyone able to shed any light on my thought processes on setting up the simulation correctly using turbulence models, or perhaps where else I may be going wrong? I've attached my case at the following google drive link if anyone could be so kind to take a look and offer any advice on getting this running and heading towards validation - it's been troubling me for some time now! https://drive.google.com/open?id=0B3...UJxc1BpTS1XZDQ Best regards, Dave |
November 30, 2016, 10:57 |
Dave
Rep Power: 10 |
For ease of reference my simulation criteria have been calculated as follows:
Literature values: Turbulence model: kOmegaSST U = 2.8 m/s Tip speed ratio = 2 Turbulent Intensity, I = 2% Chord Length = 0.032 m Time step = 1 rot deg/time step = 2.707e-04 s Calculated values: p = constant Turbulent Viscosity, nut = 2.4e-03 Turbulent Energy, k = 4.704e-03 Specific Dissipation Rate, omega = 1.9595 Turbulent Length Scale = ~5% of inlet height = 0.035 Angular velocity, omega = 64 rad/s Anything particularly obvious that could be wrong? |
November 30, 2016, 12:26 |
CFD
Rep Power: 16 |
Hello Dave,
I have done similar simulations before and found some good case files that they might be helpful in terms of the setup etc. One of the cases works fine on OpenFoam v 2.3.2. The other case file requires some work to get it to work. Anyway, the file are uploaded in mediafire; HTML Code:
http://www.mediafire.com/file/4mia94y679r645d/OpenFOAM-2D-VAWT-master.zip HTML Code:
http://www.mediafire.com/file/n8sjaavaapcqvay/Naca-TSR1.0.zip Best, |
December 1, 2016, 04:30 |
Dave
Rep Power: 10 |
Hi Khamlaj,
Thanks very much for those, I'll look over them today and report back any findings! All the best, Dave |
December 1, 2016, 11:19 |
#5 | |
Dave
Rep Power: 10 |
Hi again Khamlaj,
The second mesh seems to be faulty as it doesn't load in ParaView, detailing the error: Quote:
Do you think this is then indicative of a mesh problem, rather than the initial conditions listed in my 0 directory? I have also wondered if simulation failure is related to the fvSchemes and fvSolutions dictionary.. What are your thoughts on this? I don't feel I understand these dictionaries very well - perhaps this could be the root of the problem? Thanks again for your time, Dave |
Facing a floating point error when reducing time step in a unsteady simulation | withwolf | STAR-CCM+ | 7 | November 14, 2018 19:38 |
Floating point exception (yes...) | sandri_92 | OpenFOAM Running, Solving & CFD | 0 | October 23, 2016 14:42 |
rhoCentralFoam - kOmegaSST - Floating point exception | DGW | OpenFOAM Running, Solving & CFD | 1 | September 1, 2016 07:45 |
simpleFoam: floating point exception | student666 | OpenFOAM Running, Solving & CFD | 9 | March 13, 2016 18:23 |
Floating point exception (core dumped) for GAMG solver | yuhou1989 | OpenFOAM Running, Solving & CFD | 2 | March 24, 2015 19:28 |
