Questions about the integration scheme in Lagrangian frame |
November 28, 2016, 08:46 |
#1 | |||
Rep Power: 9 |
Dear Foamer:
The integration schemes in the Lagrangian frame only contain Euler & Analytical, so I'm trying to implement the Runge Kutta method inside. The member functions in IntegrationScheme.H is: Quote:
Best regards, ycui |
December 6, 2016, 10:51 |
#2 | |
Rep Power: 9 |
I find the answer: there are user defined type, different integration scheme has a different types.
June 12, 2017, 16:32 |
Clint
Rep Power: 11 |
They are just constants for your integration. You can see how they are defined, at least for your case, about 4 lines above the call to integrate in KinematicParcel.C
August 13, 2023, 03:54 |
rqli
hello ,did you successfully use RK nethod , i also wang to do this thing, can you give me some help
Implementation of QUICK scheme | Romuald Skoda | Main CFD Forum | 11 | November 6, 2017 21:20 |
AUSM scheme ? Central Scheme | boling | Main CFD Forum | 7 | January 7, 2016 02:41 |
Godunov scheme | Peter | Main CFD Forum | 6 | November 27, 2009 10:51 |
extrapolation in MUSCL scheme | Chandra | Main CFD Forum | 6 | February 14, 2007 11:21 |
Question on Sediment Mass Conservation Scheme | Wen Long | Main CFD Forum | 0 | July 6, 2004 15:45 |
