Numerical diffusion between TVD and NVD schemes
Old   November 21, 2016, 08:14
Default Numerical diffusion between TVD and NVD schemes
Wenkun Zhao
Eric Brant is on a distinguished road
Hi all formers,
I recently calculated a compressible flow using rhoCentralFoam and I found quite difference between the results when using different interpolationSchemes in fvSchemes file.
The default interpolationSchemes for "reconstruct()" is VanLeer(V):
    default                linear;
    reconstruct(rho)    vanLeer;
    reconstruct(U)      vanLeerV;
    reconstruct(T)      vanLeer;
I found the result is sort of over dissipation, but when I use Gamma
    default                linear;
    reconstruct(rho)    Gamma    0.2;
    reconstruct(U)      GammaV  0.2;
    reconstruct(T)      Gamma    0.2;
the results are better. I don't know why they are different since they are all second order schemes. It means that VanLeer is more numerical diffusive?
Any suggestions?
Eric Brant is offline   Reply With Quote
Nvd / tvd MichiB OpenFOAM Programming & Development 8 July 21, 2021 06:27
Need modification for MUSLE or MC schemes liuhuafei OpenFOAM Bugs 3 June 13, 2010 03:38
TVD ... Questioner Main CFD Forum 1 June 7, 2006 09:54
