Strange Hydrostatic Boundary Backflow with interFoam
Old   November 15, 2016, 22:32
Default Strange Hydrostatic Boundary Backflow with interFoam
KTG
Abe
KTG is on a distinguished road
Hello Foamers,
I am having a strange issue when using interFoam with a hydrostatic boundary condition. The general setting is that I have two plates with a narrow gap between them. A thick, laminar liquid is flowing into the gap under a constant head, hydrostatic boundary condition. So I am using the interFoam solver. The liquid that is displacing the air is orders of magnitude denser, so I just set the boundaries to zero pressure where the air is exiting the gap.
flow.png shows the simulation after 40 seconds.
backflow.png is the same, but with forward streamlines. You can clearly see that the section that is assigned the uniformDensityHydrostaticPressure condition has split itself between inflow and outflow. I can't figure this out, because the pressure there is greater than zero.
Here are the boundary conditions for pgh (the "freeinlet" patch is located directly above the uniformDensityHydrostaticPressure patch):
boundaryField
    inlet
        type            uniformDensityHydrostaticPressure;
        rho             1263.9;
        pRefValue       0;
        pRefPoint       (0 0 .16);
        value           uniform 0; // optional initial value
    freeinlet
        type            fixedValue;
        value            uniform 0;
    outlet
        type            fixedValue;
        value            uniform 0;
    wedgewalls
        type            fixedFluxPressure;
    lid
        type            fixedValue;
        value            uniform 0;
for U:
boundaryField
    inlet
        type        zeroGradient;
    freeinlet
        type        zeroGradient;
    outlet
          type            inletOutlet;
          inletValue      uniform (0 0 0);
          value              uniform (0 0 0);
    wedgewalls
        type            fixedValue;
    lid
        type            slip;
and alpha.water:
 boundaryField
    inlet
        type            inletOutlet;
        inletValue      uniform 1;
        value           uniform 0;
    freeinlet
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    outlet
        type            inletOutlet;
        value           uniform 0;
    wedgewalls
        type            zeroGradient;
    lid
        type            inletOutlet;
        value           uniform 0;
    defaultFaces
        type            empty;
Any ideas would be greatly appreciated! I have been messing with the geometry of this to try to make it a little more stable, but I think the real issue is in my boundary conditions. I can't figure out why the zero pressure boundaries seem to have zero flux, but the hydrostatic one has some flow that seems to defy the pressure gradient.
Thanks!
KTG is offline   Reply With Quote
boundary conditions, hydrostatic pressure, interfoam
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
