November 8, 2016, 11:23 |
Error during tutorial 2.1.5.3 Mapfields
#1 | ||
Roy
Hey everybody,
I just started using openFOAM and am working my way through the tutorial. So far I encountered a few problems which I eventually was able to fix myself with a little search here and there. However during step 2.1.5.3 of the tutorial I am now stuck. I created a new folder cavityFine in the workingDir using as in 2.1.5.1 of the tuturial: mkdir cavityFine cp -r cavity/constant cavityFine cp -r cavity/system cavityFine cd cavityFine Then I edited the blockMeshDict file as described in step 2.1.5.2 of the tutorial, subsequently ran blockMesh (this works). However during step 2.1.5.3 when I execute the command: mapFields ../cavity -consistent The utility should run with output to the terminal including: Quote:
Regards, |
November 8, 2016, 13:17 |
Arsalan
Rep Power: 12 |
Hi Roy,
Problem is explained obviously in the error text, just read it. Check if the controlDict is exist at cavity/system. Regards, Arsalan. |
November 9, 2016, 09:47 |
Roy
November 9, 2016, 14:12 |
Mahdi Hosseinali
Rep Power: 18 |
Are you sure you are in the right directory?
It should read: Source: ”..” ”cavity” Target: ”<path>” ”cavityFine” but in the attached picture it says: source "." "cavity" Target: ”<path>” ”cavityFine” Note the single and double dots on the first line. You should be in cavityFine when running the mapFields utility. Also both cases should be in the same directory for .. to be able to address the cavity case |
cavity, cavityfine, error, mapfields, tutorial |
tutorial files | KITetima | FLUENT | 8 | November 23, 2019 17:05 |
AMI - Propeller Tutorial diverging | kingmaker | OpenFOAM Running, Solving & CFD | 2 | November 4, 2016 03:57 |
STAR-CD Tutorial | shekhar aryal | STAR-CD | 4 | March 22, 2010 04:25 |
CFD-ACE Tutorial for Serpentine Fuel cell Channel | Taqi | Main CFD Forum | 0 | April 13, 2008 14:12 |
Rotor/stator tutorial, and how to... | gilberto | CFX | 5 | January 21, 2002 10:41 |
