Problem with Acoustic Pulse Simulation
Old   November 6, 2016, 05:40
Question Problem with Acoustic Pulse Simulation
Weng-Ji Chen
Weng-Ji is on a distinguished road
Hi, I want to test sound wave simulation solver, therefore I make a single acoustic pulse with groovyBC and have the viscosity term zero.
My solver is rhoCentralFoam and the faces except for inlet and outlet are cyclic. Outlet is wave transmissive.
In the first case, the distance between the inlet and the outlet is about 3 times the width of acoustic pulse. It seems to be good. The pulse can propagate from the inlet to the outlet and remain the waveform.
However, when I elongate my chamber size, that is, have the distance between the inlet and outlet be 30 times the width of pulse, the peak of the pulse begins to oscillate. It decays, grows, decays ... Obviously, something went wrong.
http://imgur.com/5tFGnyC
peak time evolution
I make sure the boundary conditions, time step and the mesh size are the same. Here are my boundary conditions:
|  \\    /   O peration     | Version:  v1606+                                |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 1e5;
boundaryField
    inlet1
       type            zeroGradient;
    outlet
        type            waveTransmissive;
        phi             phi;
        psi             thermo:psi;
        rho             rho;
        gamma           1.3;
        fieldInf        1e5;
        lInf            50;
        value           $internalField;
    right
        type            cyclic;
    left
        type            cyclic;
    up
        type            cyclic;
   down
        type            cyclic;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet1
       type           groovyBC;
       valueExpression "vector(10*pow(e,-(time()-0.00017)*(time()-0.00017)/0.000000002),0,0)";
        variables "e=2.7182;"
      //omega=2*pi/0.00004;";
       timelines ();
       value uniform (0 0 0);
    outlet
        type            pressureInletOutletVelocity;
        inletValue      uniform (0 0 0);
    right
        type            cyclic;
    left
        type            cyclic;
    up
        type            cyclic;
 down
        type            cyclic;
FoamFile
    version     2.0;
    format      ascii;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 300;
boundaryField
    inlet1
        type            fixedValue;
        value           uniform 300;
    outlet
        type            inletOutlet;
        inletValue      uniform 300;
        value           uniform 300;
    right
        type            cyclic;
    left
        type            cyclic;
    up
        type            cyclic;
    down
        type            cyclic;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType
    type            hePsiThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
mixture
    // normalised gas
    specie
        nMoles      1;
        molWeight   28.96;
    thermodynamics
        Cp          1004.5;
        Hf          2.544e+06;
    transport
        mu          0;
        Pr          1;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
vertices
    (0 0 0)
    (2004 0  0)
    (2004 1 0)
    (0 1 0)
    (0 0 1)
    (2004 0 1)
    (2004 1 1)
    (0 1 1)
blocks
     hex (0 1 2 3 4 5 6 7) (2004 1 1) simpleGrading (1 1 1)
edges
boundary
    inlet1
        type patch;
        faces
            (0 4 7 3)
    outlet
        type patch;
        faces
           (1 2 6 5)
    right
        type  cyclic;
        neighbourPatch left;
        faces
            (2 3 7 6)
    left
        type cyclic;
        neighbourPatch right;
        faces
            (0 1 5 4)
    up
       type cyclic;
       neighbourPatch down;
       faces
           (4 5 6 7)
    down
       type cyclic;
       neighbourPatch up;
       faces
           (0 1 2 3)
mergePatchPairs
Besides, I tried sinusoidal wave. It went well, then I elongated the chamber and the same problem occurred.
Any advises will be helpful, thank you.
Weng-Ji is offline   Reply With Quote
Problem in initializing transient simulation with a finer mesh sidd CFX 8 April 29, 2016 03:25
Low pressure de Laval simulation convergence problem heksel8i FLUENT 3 July 22, 2013 11:28
Dynamic mesh simulation (pimpleDyMFoam) problem sidlof OpenFOAM Running, Solving & CFD 6 April 12, 2013 12:24
the problem of my transient simulation "Floating point exception: Overflow " alloveyou CFX 15 November 22, 2012 12:14
about valve closing problem during ANSYS FSI simulation ivy CFX 4 June 8, 2011 22:01
