refCell for Laplacian in a periodic box
Old   November 5, 2016, 10:50
Exclamation refCell for Laplacian in a periodic box
gigilentini8 is on a distinguished road
Hi all,
I am solving a simple diffusion problem on a periodic (cyclic condition) box with regular grids.
I start from random values in each cell (either as initial condition or source term in steady diffusion) and I let the Laplacian do the smoothing it is supposed to do
everything works as expected, apart that strange over(under-)shoots appear in the cell where I set my reference value (needed of course due to periodicity), in a consistent way. i.e., I repeated several times with different random seeds and realisations and the values at the refCell or refPoint are always much lower or much larger than the rest of the domain.
It looks like the reference values are not exactly doing their job.
I am using all linear uncorrected schemes and OF 4.x
any clue on how to solve this?
my code is as simple as this
    while (simple.loop())
           fvScalarMatrix TEqn  (
                fvm::ddt(T) - fvm::laplacian(DT, T) +  fvOptions(T)
                == -ff
        TEqn.relax();
        TEqn.setReference(TRefCell, TRefValue);
        fvOptions.constrain(TEqn);
	      TEqn.solve();
		    fvOptions.correct(T);
gigilentini8 is offline   Reply With Quote
Old   November 5, 2016, 11:08
Default Solved!
Ok, the problem was just that I was smoothing so much that the mismatch I saw between the refPoint and the rest of the domain was maybe a real effect due to the statistical error
with much smaller diffusion coefficient, I can get a nice smooth Gaussian Random Field
cyclic, laplacian operator, laplacianfoam, refcell, refvalue
cyclicAMI and interDyMFoam for periodic box kwardle OpenFOAM 1 March 11, 2014 14:40
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 12:25
Initial Velocity Field - 2D Turbulence in a Periodic Box AHutchison OpenFOAM Running, Solving & CFD 0 May 28, 2013 01:18
HELP! Periodic Problem foxer FLUENT 1 June 27, 2012 09:00
[ICEM] how to define periodic in icem ? mingersai ANSYS Meshing & Geometry 1 February 3, 2012 18:46
