Out of memory while sampling surfaces
Old   November 2, 2016, 18:33
Default Out of memory while sampling surfaces
xuegy is on a distinguished road
Hello all,
I have encountered a memory trouble. My workstation has 128GB memory and my case will occupy about 80GB memory while running. I need to save 2 surfaces instead of the whole result so I added functions in my controlDict. However everytime this sampling code leads to an out of memory problem.
functions
	mysurfaces
		type            surfaces;
		functionObjectLibs
			"libsampling.so"
		writeControl    adjustableRunTime;
		writeInterval   0.005;
		surfaceFormat   vtk;
		interpolationScheme cellPoint;
		fields
			p
			U
		surfaces
			surfaceXZ
				type plane;
				basePoint (0.1001 0.1001 0);
				normalVector (0 1 0);
			surfaceYZ
				type plane;
				normalVector (1 0 0);
	myline
		type            sets;
		functionObjectLibs
			"libsampling.so"
		setFormat   raw;
		fields
			U
		sets
			lineZ
				type        uniform;
				axis        z;
       				start       (0.1001 0.1001 0);
        			end         (0.1001 0.1001 0.8);
        			nPoints     401;
So it is incredible that sampling a surface will occupy more that 40GB memory. I don't want to modify the mesh or the solver. So is there any method to reduce the memory usage when sampling these surfaces?
Thanks
xuegy is offline   Reply With Quote
Old   November 3, 2016, 09:13
Bruno Blais
blais.bruno is on a distinguished road
That is indeed a very troubling amount of memory.
Does the same error occur if you try to save only P instead of U and P or it does not change? Are you using the latest version? This seems very anormal, so there might be an underlying bug that manifest itself only for very large cases...
Originally Posted by xuegy View Post
Hello all,
functions
    mysurfaces
        type            surfaces;
        functionObjectLibs
            "libsampling.so"
        surfaceFormat   vtk;
        fields
            p
            U
        surfaces
            surfaceXZ
                type plane;
            surfaceYZ
                type plane;
    myline
        type            sets;
        functionObjectLibs
            "libsampling.so"
        setFormat   raw;
        fields
            U
        sets
            lineZ
                type        uniform;
                axis        z;
                    nPoints     401;
Thanks
blais.bruno is offline   Reply With Quote
Old   November 3, 2016, 12:03
I'm using the latest version of deb pack. I've tested this case on a half-size mesh(1/8) and everything runs smoothly.
If I only save one surface of U it's safe. About 15GB will be occupied when writing. But if I add the line sampling it will crash again. I should go back and test each value separately so that I can know where is the problem.
Parallel partition memory allocation problem Jepice Fidelity CFD 2 July 28, 2017 18:20
Run-time memory allocation error akalopsis CFX 0 November 17, 2014 18:17
Lenovo C30 memory configuration and discussions with Lenovo matthewe Hardware 3 October 17, 2013 11:23
RAM memory problem alpha Main CFD Forum 8 February 12, 2008 12:07
"Memory too low" problem with Fluent HELP NEEDED Amr FLUENT 6 May 8, 2006 13:06
