Parallel decomposition
Old   November 2, 2016, 12:07
Default Parallel decomposition
koscfd is on a distinguished road
Dear All,
I am running a transient multiphase analysis using interFoam solver and I am trying to use all processors of my PC (6 cpus) in order to reduce the running time.
I used the parallel decomposition and so far have tried the "scotch", "simple" and "hierarchical" methods and the analysis runs much faster!
For example:
No mesh decomposition (base case): Run time= 20hours
"scotch" mesh decomposition: Run time= 5.5hours
The problem is that with the "scotch" method I get very different results from my base case. With the "simple" and "hierarchical" methods, I get results of the same magnitude as compared to my base case, but still not identical.
Do you know if there is a way to use all processors and get identical results with my base case?
Thank you in advance,
Koscfd
p.s. I am using OpenFOAM version 3.0.
koscfd is offline   Reply With Quote
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
[snappyHexMesh] shm in parallel with simple decomposition mihaipruna OpenFOAM Meshing & Mesh Conversion 6 July 16, 2015 05:55
parallel results different depending on decomposition strategy franzisko OpenFOAM 3 November 4, 2009 07:37
