mpirun start second run on same processor as the already running
Old   November 2, 2016, 09:40
Default mpirun start second run on same processor as the already running
Simon Johansson
Simjoh is on a distinguished road
I've my cases running nice and smooth as long as I run them one by one.
mpirun -np 2 interFoam -parallel >log.interFoam
But when I start multiple simulations from different case directories. I get all my jobs started on the very same processor ID. Each process then allocate 50% of the processor ID.
I guess it has to do with my mpi installation rather then with my openfoam installation. But I know a lot of you guys knows a lot about mpirun.
I followed this walktrough to install openfoam 3.0.1 on ubuntu 16.04
https://openfoamwiki.net/index.php/Installation/Linux/OpenFOAM-3.0.1/Ubuntu
Thanks for any help or pointer!
Simjoh is offline   Reply With Quote
Old   November 2, 2016, 10:58
Simon Johansson
I kind of solved this problem with --cpu-set flag.
mpirun -np 2 --cpu-set 4-5 interFoam -parallel
I use a intel i7 5820k with 6 cores and hyperthreading turned off. If you use a quad core you would need to chang 4-5.
I think that mpirun should be able to to manage to do this by itself and is therefor not satisfied with my solution.
Hope someone finds this useful anyway.
/Simon
Old   November 3, 2016, 14:07
xuegy is on a distinguished road
Maybe you can try with '-bind-to core'. With that you can even turn on hyper threading without any trouble.
xuegy is offline   Reply With Quote
Old   November 3, 2016, 14:46
Simon Johansson
Thanks xuegy for your reply.
Will try your suggestion next time I'm at office.
About hyper threading I heard a lot about it being of no use together with open foam.
Old   November 9, 2016, 03:59
Simon Johansson
Tanks for the input but it didn't help. I'll stick to declaring processor myself until i get some other working suggestions..
Old   February 21, 2024, 08:09
Lightbulb
Thiago Parente Lima
thiagopl is on a distinguished road
Hi all,
For those who ended up here I recommend this material about running OpenFOAM in parallel which approachs the hyperthreading issues.
Module 4 | Running in parallel #openfoamtraining
http://www.wolfdynamics.com/wiki/parallel.pdf
At the playlist below you can see the videos of Module 4.
https://www.youtube.com/playlist?lis...mDChejiwm846Wl
Hope it helps.
Regards.
Fields of interest: buoyantFoam, chtMultRegionFoam.
thiagopl is offline   Reply With Quote
mpirun
Error running simpleFoam in parallel Yuby OpenFOAM Running, Solving & CFD 14 October 7, 2021 05:38
Transient run continues from last time (when startover is desired) bongbang CFX 2 March 23, 2015 00:05
Can not run OpenFOAM in parallel in clusters, help! ripperjack OpenFOAM Running, Solving & CFD 5 May 6, 2014 16:25
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
