convergence in OpenFoam
Old   October 24, 2016, 10:38
Default convergence in OpenFoam
annn
cleoo is on a distinguished road
how do you know that your soltuion has converged?
because sometimes if it converged before the endTime it will say it has 'converged in x iterations' so does that mean if you reached you end time and it still hasn't said that it hasn't converged?
I am asking about this because I am running a transient simulation and after several hundred iterations I see no change when I look at the results, so to me I am guessing it has reached a steady state which means it converged, is this correct? and to mention, it has not reached the endTime yet
is this too trivial?
cleoo is offline   Reply With Quote
Old   July 16, 2017, 06:46
the_edge123 is on a distinguished road
pyFoamPlotWatcher.py may help
Fabien
the_edge123 is offline   Reply With Quote
Old   August 25, 2017, 06:55
Anders Utnes
Alasir is on a distinguished road
You may have to specify what kind of solver you are using. But assuming that you are using one that is designed to converge to a steadystate solution:
If it converges in x iterations before reaching the end time then it has reached what it belives is a steady state.
If it's not in a steady state yet, you may have to check if your convergence criteria are to relaxed.
If it's been in a steady state for a while but your simulaton is not stoping, the convergence criteria may be to strict.
If it reaches the end time then it could not find a convergent solution in the given time.
Alasir is offline   Reply With Quote
openfoam 4
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 20:00
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
