Problems converting simpleFoam/motorBike to kOmegaSSTDES |
October 21, 2016, 05:58 |
Per Jørgensen
Rep Power: 14 |
I have had problems finding a working kOmegaSSTDES example, so I tried to modify the simpleFoam/motorBike tutorial to pimpleFoam with kOmegaSSTDES. After a few iterations the simulation blows up. What do I do wrong? Shoulld the wall boundary conditions be modified? Best regards, Per |
October 28, 2016, 07:11 |
Per Jørgensen
Rep Power: 14 |
The problem appears to be that kOmegaSSTDES is very sensitive to strong gradients.
I go it to work by slowly ramping up the speed. The method used in the other motorcycle example with precalculating a static solution as initial value does not seem to work here... |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
[Commercial meshers] Problems after converting a CCM Model | sErik | OpenFOAM Meshing & Mesh Conversion | 10 | November 24, 2009 03:37 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
unstructured grid | sreekanth | Main CFD Forum | 1 | August 6, 2001 15:09 |
Inverse problems | Aleksey Alekseev | Main CFD Forum | 0 | May 12, 1999 15:38 |
