Simulation of viscoelastic fluids subjected to shear stresses
Old   October 19, 2016, 08:04
Default Simulation of viscoelastic fluids subjected to shear stresses
Nagesh Atreyas is on a distinguished road
Hello Dear Foamers,
I am trying to simulate a viscoelastic fluid which passes in-between two cylinders. The cylinders along with rotation will also undergo latitudinal movement/latitudinal oscillations.
Now I have three plots of this fluid obtained from Rheometer viz;
Shear modulus vs deformation (from amplitude test), Shear modulus vs angular frequency (from frequency test) and Viscosity vs shear rate (from rotation test).
As far as I have understood, viscoelasticfluidFOAM models do not have provision to include G' (shear storage modulus) and G" (shear loss modulus) which altogether makes up G (shear modulus). Can someone tell me how I could implement this in viscoelasticFOAM??!
Or, if I have understood the viscoelasticfluidFOAM models wrongly and G is readily implemented in the model, would you guys be kind enough to inform about it please?
Any help/suggestion would be greatly appreciated. From already existing posts/threads I could not figure this out clearly and hence I have started a new thread.
Disclaimer: I am very new to viscoelastic fluids and rheometry and OpenFOAM programming/programming in general is not my strong point either.
Thanks in advance
Nagesh
Nagesh Atreyas is offline   Reply With Quote
Old   October 27, 2016, 05:02
Anyone please??!
Boundary Condition definition for Tensorial Fields and viscoelastic flow simulation titio OpenFOAM Running, Solving & CFD 1 February 4, 2009 10:14
simulation with 2 fluids: air and water Rogerio Fernandes Brito CFX 4 March 20, 2008 19:07
Shear stresses Vidya FLUENT 1 July 10, 2006 05:59
using two fluids in simulation ousegui CFX 4 May 15, 2006 22:53
Large Eddy simulation Andreas Hauser Main CFD Forum 1 May 20, 2000 21:33
