reactingFoam "maximum number of iterations exceeded" on mesh that works fine w/o chem |
October 15, 2016, 20:34 |
#1 | |||
Anonymouse
Rep Power: 11 |
So, I have a mesh and general setup that works just fine with rhoCentralFoam and no chemistry. checkMesh only reports cell concavity errors (which are unavoidable for anything made with snappyHexMesh where the resolution varies - they occur at each resolution transition zone). Non-orthogonality is low, only 36.2 max, 6.08 average.
I'm now trying adding in chemistry (at this point, I'm pretty indifferent to the solver, I just want something that runs; I can work from there). But something curious is happening. It runs fine if I remove aluminum and all aluminum reactions from my reactions list. But if I add them in, it crashes after just 2 or 3 timesteps: Quote:
So, since it happens when aluminum is in the list of reactants - even if I don't list any reactions for it - my first thought was, there must be something wrong with my thermodynamics definition: Quote:
So what could be wrong? What can I do to try to debug this? I've run out of ideas here... In case it matters: it's a O2/N2 atmosphere (air), N2 listed as an inert gas, and there's a flowRateInletVelocity injecting a mixture of cryogenic aluminum dust, wax, and oxygen (all treated as a gas so that I don't have to track particles - I may migrate to a particle-based system later. I'm using EulerImplicit as the solver, but even if I change it to no solver / chemistry off the crash happens. Thermotype is: Quote:
October 16, 2016, 18:19 |
Anonymouse
Rep Power: 11 |
Bout of minor inspiration... it's only the highCpCoeffs in aluminum that are causing the problem; I can replace just them, and it runs, but with them in place the max iter error occurs.
If I swap out the second to last janaf param for a lower one, it works too. Real, crashes: highCpCoeffs ( 2.348620.000143612 -4.23667e-08 2.72036e-12 3.70085e-16 39104.1 6.37634 ); Altered, works: highCpCoeffs ( 2.348620.000143612 -4.23667e-08 2.72036e-12 3.70085e-16 -958.396 6.37634 ); Need to figure out what's going on here... |
October 16, 2016, 20:11 |
Anonymouse
Rep Power: 11 |
Update: Well, that's the enthalpy offset. And the reason for the big enthalpy offset is the heat of condensation of aluminum at Tcommon:
https://www.citrination.com/uploads/...tate-reference I calculate T=2790 (low params) at entropy 84441 and T=2791 (high params) at entropy 382175, which are roughly what show in the graph (T=2791: 87670->381700). I'm calculating as: R * (a[4]*math.pow(T, 5)/5 + a[3]*math.pow(T, 4)/4 + a[2]*math.pow(T, 3)/3 + a[1]*math.pow(T, 2)/2 + a[0]*T + a[5]) ... which should be correct. But my best guess has to be that this problem relates to the large enthalpy difference at that point? The thing is, it's a *real* large jump in enthalpy there, I have to account for it.... |
October 16, 2016, 22:18 |
#4 | |
Anonymouse
Rep Power: 11 |
I think the code that's failing is:
My parsing of what it's doing: it's trying to find what temperature a chemical species is going to end up at... which depends on the specific heat differences en route to the new temperature, aka the net enthalpy change. "Test" is the previous temperature it tried and TNew is the new attempt, which is based on trying to follow the slope of some function (specific heat?) in some manner.... I'm going to instrument the code to try to find out. |
October 16, 2016, 22:20 |
Anonymouse
Rep Power: 11 |
The results of instrumenting thermophysicalModels/specie/lnInclude/thermoI.H:
T(f=906725, p=62165.7, T0=1035.48) tol=0.0001, Ttol = 0.103548 Test=1035.48, Tnew=875.878 (1.10861e+06, 201886, 1264.9, 875.878) Test=875.878, Tnew=1053.82 (684624, -222101, 1248.13, 1053.82) Test=1053.82, Tnew=876.255 (1.13184e+06, 225111, 1267.73, 876.255) Test=876.255, Tnew=1053.81 (685095, -221630, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) Test=1053.81, Tnew=876.254 (1.13182e+06, 225097, 1267.73, 876.254) Test=876.254, Tnew=1053.81 (685094, -221631, 1248.2, 1053.81) --> FOAM FATAL ERROR: Maximum number of iterations exceeded in file /opt/OpenFOAM/OpenFOAM-dev/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib64/libc.so.6" #7 ? at ??:? So, to narrow this down. Tnew is: Tnew = (this->*limit) (Test - ((this->*F)(p, Test) - f)/(this->*dFdT)(p, Test)); So, when we see: Test=1035.48, Tnew=875.878 (1.10861e+06, 201886, 1264.9, 875.878) it's saying: 875.878 = (this->*limit)(1035.48 - ((this->*F)(62165.7, 1035.48) - 906725) / (this->*dFdT)(62165.7, 1035.48)) 875.878 = (this->*limit)(1035.48 - (1108611 - 906725) / 1264.9) 875.878 = (this->*limit)(1035.48 - 201886 / 1264.9) 875.878 = (this->*limit)(1035.48 - 159,59) 875.878 = (this->*limit)(875.878) Then this runs it in reverse: Test=875.878, Tnew=1053.82 (684624, -222101, 1248.13, 1053.82) 1053.82 = (this->*limit)(875.878 - ((this->*F)(62165.7, 875.878) - 906725) / (this->*dFdT)(62165.7, 875.878)) 1053.82 = (this->*limit)(875.878 - (684624 - 906725) / 1264.9) 1053.82 = (this->*limit)(875.878 - -222101 / 1264.9) 1053.82 = (this->*limit)(875.878 + 175,59) 1053.82 = (this->*limit)(1053.82) So it just cycles between these two points (~875 and ~1053). But why? Also: strange that this is *below Tcommon*. Tcommon is 2790.812.... Yet when I had previously tried swapping out the high Cp coeffs for aluminum with those from N2, it had worked... Still not sure what function "*F" is supposed to be here... looks too high to be enthalpy J/K-mol (1.1e6 at 1035K?), and way too high for specific heat or entropy (J/mol).... Also, it's something that's pressure-dependent... hmm.... maybe it's not per-mole, maybe it's.... per... something else? ED: If I swap out the low Cp coeffs on aluminum, the output is exactly the same. Huh??? Okay, so maybe we're not dealing with aluminum here.... even though when I change the thermo data for aluminum, or remove aluminum from the run altogether, it works? *mind boggles* |
October 17, 2016, 19:13 |
Anonymouse
Rep Power: 11 |
Okay, so some results of further tests.
*F is the function Hs. So, enthalpy. *dFdT is the function Cp. So, specific heat. Which makes sense, that is indeed the derivative of enthalpy. For p=62165.7, T=1035.48 Hs returns hs(p, T) / W(). hs is 26182800 and W is 23.6177, hence the 1108610 Cp returns cp(p, T) / W(). cp is 29873.9 and W is 23.6177, hence the 1264.9 Again, these don't look like H or Cp per mole, they must be per mass or per volume. cp() appears to be: const coeffArray& a = coeffs(T); return RR* ( ((((a[4]/5.0*T + a[3]/4.0)*T + a[2]/3.0)*T + a[1]/2.0)*T + a[0])*T + a[5] ) + EquationOfState::h(p, T); ... while hs is: const coeffArray& a = coeffs(T); return RR* ( ((((a[4]/5.0*T + a[3]/4.0)*T + a[2]/3.0)*T + a[1]/2.0)*T + a[0])*T + a[5] ) + EquationOfState::h(p, T) - hc(); In practice: cp: 29940.7 + 0 hs: 2.61367e+07 + 0 - -594257 Sooooo the numbers actually are this large, straight from the janaf params....? Okay, need to figure out how *that's* happening.... enthalpy should only be on the order of 30k J/K-mol and specific heat on the order of 30 J/mol... Let+s instrument that better: 29940.7 = 8314.47*((((-5.02086e-15*1053.81 + 7.87828e-11)*1053.81 + -4.41075e-07)*1053.81 + 0.00112498)*1053.81 + 2.81934)) 2.61367e+07 = 8314.47*((((-5.02086e-15/5.0*1053.81 + 7.87828e-11/4.0)*1053.81 + -4.41075e-07/3.0)*1053.81 + 0.00112498/2.0)*1053.81 + 2.81934)*1053.81 + -303.117)) + 0 - -594257 25542443 = 8314.47*((((-5.02086e-15/5.0*1053.81 + 7.87828e-11/4.0)*1053.81 + -4.41075e-07/3.0)*1053.81 + 0.00112498/2.0)*1053.81 + 2.81934)*1053.81 + -303.117)) Huh, wait a minute.... R is 8314.47? What sort of units are those? I've been using R=8.314, aka J/mol-K. That R has to be, what, cm3 kPa/K-mol or something weird? Then that raises the question.... should I be accepting that OpenFOAM is wanting cp values in these sort of unexpected units... or are they expecting the janaf coefficients to be expressed in some sort of weird units, and then converting them to J/mol-K? My parameters *must* be at least approximately right, certainly not off by an order of 1000, because they match pretty closely to janaf params in thermo files that come with the distributions (where matching species can be found). The coefficients should all be off by about three orders of magnitude if I was doing it wrong. Another oddity: I don't recognize those janaf coefficients it lists! They're not anywhere in my thermo.compressibleGas file! Yet strangely the results aren't that far off for aluminum, if you scale the R by 1000..... God, I am so baffled here.... Ed: I think trying to understand how OpenFOAM is representing the data internally is leading me astray. The real problem is, I think, that we have some sort of local discontinuity between these ends - each side thinks it has to go a long way because of a low gradient, but in-between the two there's a high gradient. Something like that, right? Last edited by KarenRei; October 17, 2016 at 22:44. |
October 18, 2016, 20:28 |
Anonymouse
Rep Power: 11 |
So, I'm going to basically class this as, "Hey OpenFOAM - it's not me, it's you". It's my view that their convergence algorithm is fundamentally flawed - that it'll work most of the time, but not all of the time. I have gone and patched it.
For others experiencing this problem, you should do the following. 1) Open src/thermophysicalModels/specie/lnInclude/thermoI.H and find inline Foam::scalar Foam::species::thermo<Thermo, Type>::T 2) Replace the current maxIter check that aborts with: if (iter++ > maxIter_ / 2) { iter = 0; do { const scalar scaledown = 1.0 - iter / (maxIter_ / 2.0); Test = Tnew; Tnew = (this->*limit) (Test - scaledown * ((this->*F)(p, Test) - f)/(this->*dFdT)( if (iter++ > maxIter_ / 2) { FatalErrorInFunction << "Maximum number of iterations exceeded" << abort(FatalError); } } while (mag(Tnew - Test) > Ttol); break; } This basically forces convergence by cutting the distance that it may travel per hop, more and more with each cycle, if it fails the first half of the tolerance checks. Though it might be better to just do the whole outer loop like that rather than having the forced convergence be a "in case of failure" scenario - I'm not sure which would be best. But anyway, to anyone else who encounters this (the main reason I've basically been debugging this out loud).... enjoy! |
October 18, 2016, 22:43 |
Arjun
Rep Power: 34 |
In case of openfoam, lot of magic with density scaling too happens so take care of that too.
I wish i could help but unfotunately I can not in this case. Good luck. |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 18:36 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
