SimpleFoam run in Parallel issue!
Old   October 13, 2016, 12:02
Default SimpleFoam run in Parallel issue!
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hello Foamers,
I have been running a special case using simpleFoam and came to a question that some of you might have experienced. I am trying to monitor some results including the residual using simpleFoam > log.simpleFoam command, but when I switch to mpirun -np 12 simpleFoam -parallel > log.simpleFoam, some of the output that the simpleFoam provides become 0 instead of the real values. Has anyone had this issue before could tell us the reason of not getting the results in parallel?
Best,
tareqkh is offline   Reply With Quote
Old   October 17, 2016, 14:41
Saideep
Saideep is on a distinguished road
I generally use "mpiexec -n 12 solverName -parallel > log&".
I am not sure why do you need log.simpleFoam. But I never had a problem with my statement either run on parallel or on a single core(by removing the mpi related part).
Saideep
Saideep is offline   Reply With Quote
Old   October 17, 2016, 15:45
tareqkh's Avatar
CFD
Originally Posted by Saideep View Post
Saideep
Hello Saideep,
Thank you for the answer. However, I am using a modified simpleFoam i.e. something relevant to my project. So now, the modified simpleFoam doesn't provide an output when I run in parallel. Any idea, where to look in the source code to fix the issue about not getting the results in parallel.
Best,
Old   October 19, 2016, 12:00
Default SimpleFoam in Parallel issue!
tareqkh's Avatar
CFD
Hello Foamers,
I have been running a special case using a modified simpleFoam and came to a question that some of you might have experienced. I am trying to monitor some results including the residual using simpleFoam > log.simpleFoam command, but when I switch to mpirun -np 12 simpleFoam -parallel > log.simpleFoam, some of the output that the simpleFoam provides become 0 instead of the real values. Has anyone had this issue before could tell us the reason of not getting the results in parallel? Any idea, where to look in the source code to fix the issue about not getting the results in parallel.
Best,
Old   October 21, 2016, 10:28
Saideep
It is a bit strange. Few things here. From what I understand is that,
1. your modified simpleFOAM is working when not using mpi. Can you check your results. It shall be spurious. I guess the problem comes from the modification part.
2. if results behave as you expect then the culprit is mpi, but I never encountered a problem with mpi on modifications.
Saideep
Old   October 21, 2016, 14:05
Traction is on a distinguished road
Hey,
just to be sure: Do you use the specific mpi reduce operations for generating the output in your modification ?
Traction is offline   Reply With Quote
Old   January 1, 2018, 19:07
Retired Super Moderator
Bruno Santos
Quick answer: I'm very late to this discussion, but from the description, it seems that this was a bug. But only by knowing the OpenFOAM version and the function objects used, would it be possible to at least know if this is a known bug or not.
[Salome] Salome import "Cannot find file "points" in directory..." mismichael OpenFOAM Meshing & Mesh Conversion 6 June 24, 2024 04:17
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
problem w/ running simpleFoam in parallel mazdak OpenFOAM Running, Solving & CFD 27 December 8, 2023 04:10
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Trying to run a benchmark case with simpleFoam spsb OpenFOAM 3 February 24, 2012 10:07
