October 13, 2016, 06:00 |
More stable when using large time step
Chunkan Yu
Rep Power: 9 |
Hello all,
I am facing a "strange" problem. When I use time step dt=5e-6, it runs well. But when I set dt = 1e-6, the solution will be divergent. a little strange due to the CFL-criteria. I leave my geometry here: In x-direction, the length is 2500 mm, and discreted into 100 points with simpleGrading=0.01. In y-direction, the length of one block is 12.7 mm, and discreted into 80 points with simpleGrading=0.1. the length of second block is 1004 mm, and discreted into 200 points with simpleGrading 10. In z-direction only one cell. I am doing the LES simulation with rhoPimpleFoam. tanks a lot for your suggestions and hints |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 19:50 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Sudden jump in Courant number | NJG | OpenFOAM Running, Solving & CFD | 7 | May 15, 2014 13:52 |
