Problem of simulation:InterPhaseChangeFoam error always appears |
October 12, 2016, 08:04 |
Rep Power: 10 |
Hello,everyone:
I'm new to OpenFoam, so please forgive me if my question is dumb or not complete, I'll try to offer you as more information as you need to solve this problem. I have launched a simulation in a 2D Venturi type section by using RANS model, the solver I use is InterPhaseChangeFoam. The objective is to see the turbulence flux before the critic of cavitation. But after it reports a problem like follow: --> FOAM FATAL IO ERROR: error in IOstream "/home/sihai/FOAM_RUN/tutorials/multiphase/interPhaseChangeFoam/Venturi17_test4/0.26496/p" for operation Ostream& operator<<(Ostream&, const char) file: /home/sihai/FOAM_RUN/tutorials/multiphase/interPhaseChangeFoam/Venturi17_test4/0.26496/p at line 26932. From function virtual bool Foam::IOstream::check(const char*) const in file db/IOstreams/IOstreams/IOstream.C at line 96. FOAM exiting I don't understand what it reports, can anyone help please, if the information is not enough please tell me what you need, thanks a lot. have a nice day! |
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 07:27 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 08:39 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
