Error in compressibleInterFoam
Old   October 6, 2016, 15:30
Default Error in compressibleInterFoam
Teja
gtpunnamarajuaju@gmail.co is on a distinguished road
Hi all,
I'm using compressibleInterFoam for solving the following problem: A liquid droplet falling on a liquid film. And I'm getting the following error while running the code:
Starting time loop
Courant Number mean: 0 max: 0
deltaT = 5.95238e-06
Time = 5.95238e-06
PIMPLE: iteration 1
MULES: Solving for alpha.water
Liquid phase volume fraction = 0.1 Min(alpha.water) = 0 Min(alpha.air) = 0
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for T, Initial residual = 0.603844, Final residual = 0.365488, No Iterations 1000
min(T) 300
GAMG: Solving for p_rgh, Initial residual = nan, Final residual = nan, No Iterations 1000
max(U) 0
min(p_rgh) 0
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 0 the word 'nan'
file: /auto/home/vgpunnamaraju/depthCharge3D/system/data.solverPerformance.p_rgh at line 0.
From function Foam::Istream& Foam:perator>>(Foam::Istream&, Foam::doubleScalar&)
in file lnInclude/Scalar.C at line 93.
FOAM exiting
I assume there is something wrong with my BC (p_rgh to be more specific) or my fvsolution file. So I'm attaching both of them below:
p_rgh file:
| \\ / O peration | Version: 4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 0;
boundaryField
walls
type fixedValue;
value uniform 0;
bottom
type fixedValue;
value uniform 0;
atmosphere
type totalPressure;
p0 uniform 0;
U U;
T T;
phi phi;
rho rho;
psi none;
gamma 1;
value uniform 0;
frontAndBack
type fixedValue;
value uniform 0;
fvsolution:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
alpha.water
nAlphaCorr 1;
nAlphaSubCycles 1;
cAlpha 1;
pcorr
solver PCG;
preconditioner
preconditioner GAMG;
tolerance 1e-10;
relTol 0;
smoother DICGaussSeidel;
tolerance 1e-05;
relTol 0;
maxIter 100;
".*(rho|rhoFinal)"
solver diagonal;
p_rgh
solver GAMG;
tolerance 1e-07;
relTol 0;
smoother DIC;
/* p_rgh
solver GAMG;
preconditioner
preconditioner DIC;
tolerance 1e-07;
relTol 0;
nVcycles 2;
nPreSweeps 2;
tolerance 1e-07;
relTol 0;
maxIter 20;
/*p_rghFinal
solver PCG;
preconditioner
tolerance 1e-07;
relTol 0;
nVcycles 2;
smoother DIC;
nPreSweeps 2;
tolerance 1e-07;
relTol 0;
maxIter 20;
U
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-06;
relTol 0;
nSweeps 1;
"(T|k|B|nuTilda).*"
tolerance 1e-08;
relTol 0;
PIMPLE
momentumPredictor no;
transonic no;
nOuterCorrectors 1;
nCorrectors 4;
nNonOrthogonalCorrectors 0;
Could someone please help me fix the error? I'm trying to do that from past few days and I'm not knowing what to do.
Thank you!
gtpunnamarajuaju@gmail.co is offline   Reply With Quote
Old   October 6, 2016, 16:42
Troy Snyder
tas38 is on a distinguished road
I think you want to use absolute pressure for p_rgh. Change the internalField value from 0 to say 101 kPa.
tas38 is offline   Reply With Quote
Old   October 6, 2016, 16:51
Teja
Hi Snyder,
Tried even that. I'm getting the same error. Could it be anything else?
Thank you
Old   October 7, 2016, 07:29
Troy Snyder
Does checkMesh run without any errors?
Old   October 7, 2016, 11:02
Taher Chegini
Taataa is on a distinguished road
You should set fixedFluxPressure for BC of p_rgh on walls. Also considering that you are solving a compressible flow you should set the atmospheric pressure for internal values.
Taataa is offline   Reply With Quote
compressibleinterfoam, energy equation, error, openfoam 4.0.0
