interFoam, axisymmetric, large interface U, very small deltaT
Old   October 4, 2016, 23:53
Default interFoam, axisymmetric, large interface U, very small deltaT
Qing FAN
fanq is on a distinguished road
Hello everyone,
I am doing a axisymmetric problem, a nozzle drop water on to an ellipsoid. A pressure of 5000 Pa is exerted on the inlet, and the outlet is atmosphere. I tried using Fluent, it seems to work, and I want to do it in OpenFOAM.
With OpenFOAM 4.0, the calculation stops about 0.088s, with very small deltaT:
Courant Number mean: 0.013805723 max: 0.20044358
Interface Courant Number mean: 8.5162651e-06 max: 0.010675578
deltaT = 7.9452002e-111
Time = 0.088427446
PIMPLE: iteration 1
MULES: Solving for alpha.oil
Phase-1 volume fraction = 0.062043843 Min(alpha.oil) = -6.9585342e-21 Max(alpha.oil) = 1
Phase-1 volume fraction = 0.062043827 Min(alpha.oil) = -1.4644222e-20 Max(alpha.oil) = 1
I checked the velocity, found that the velocity near interface of water and air is large. With different BCs and finer meshes, the issue still remains. I attached a picture (the white curve is the interface) and case files, any comments are grateful.
In this thread http://www.cfd-online.com/Forums/ope...ling-tank.html, TobM says
Originally Posted by TobM View Post
You haven't read the user guide .
pressureInletOutletVelocity for U is used together with totalPressure for p_rgh
After changing the type of inlet in p_rgh, my case seems to work now. Many thanks to TobM.
fanq is offline   Reply With Quote
Radiation interface hinca CFX 15 January 26, 2014 18:11
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
what happens if y+ is too large or too small Bo Jensen Siemens 12 February 20, 2003 00:31
Large volume and small flows Astrid CFX 5 April 26, 2002 06:47
