October 3, 2016, 06:24 |
modified OF version on HPC
Federica Biano
Rep Power: 10 |
Hi everyone!
I need to compile a custom version of OF3.0.1 on a HPC cluster (CentOS 7.1) and I have never done this before so I'm not familiar with environment variables and .pbs files. I try to explain what my problem is even if it is not easy at all. I compiled without errors the standard version of OF3.0.1 in $HOME/Openfoam following this guide https://openfoamwiki.net/index.php/I...CentOS_SL_RHEL. I put the modified src folder in $HOME/Openfoam/fbiano00-3.0.1 (my folder on the cluster) and I run wmake to compile it. No errors came out. Now I need to submit my jobs using the modified OF version instead of the standard version. I used this .pbs file to submit jobs with standard OF and I don't know how to modify it for my purpose. Allrun_18.pbs Code:
#!/bin/bash #PBS -A azi_prod_0 #PBS -l walltime=15:00:00 #PBS -l select=2:ncpus=16:mpiprocs=16:mem=120GB #PBS -N 18 #### File di output e di errore #PBS -o job.out #PBS -e job.err #PBS -M federica.biano@gmail.com #### Coda di sottomissione echo "Job started at " `date` #### change dir to your working directory cd $PBS_O_WORKDIR #### load bash shell cineca to set the module environment source /cineca/prod/environment/module/3.1.6/none/init/bash module purge module load gnu/4.9.2 module load openmpi/1.8.4--gnu--4.9.2 module load profile/advanced module load openfoam/3.0.1 jobid=`echo $PBS_JOBID | sed 's/[.].*//'` name=18kn ./Allrun $name > OUT.$jobid.txt echo "Job finished at " `date` exit Thanks in advance Federica |
October 6, 2016, 17:22 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Federica,
I've moved your post from the Installation forum to the Solving forum, because this seems more related to running in the HPC environment. And since you've stated that it seems to have been installed without any error messages, then we might as well move to the next step. From your description, it seems like you did not use any of the following commands before building your custom build of OpenFOAM 3.0.1: Code:
module load gnu/4.9.2 module load openmpi/1.8.4--gnu--4.9.2 module load profile/advanced module load openfoam/3.0.1 Code:
module load openmpi-x86_64 source $HOME/OpenFOAM/OpenFOAM-3.0.x/etc/bashrc foamCompiler=ThirdParty WM_COMPILER=Gcc48 FOAMY_HEX_MESH=yes However, I am a bit worried about the following statement that you wrote: Quote:
Best regards, Bruno
October 10, 2016, 10:23 |
Federica Biano
Rep Power: 10 |
Hi Bruno!
Thank you for your reply! my apologies if I posted in the wrong section. actually I replaced the four lines you mentioned with the two lines you suggested and it worked perfectly! Regarding the src folder, I followed the procedure I used to compile a new OF library on my computer, but on the cluster, so since I modified a sixDoFRigidBodyMotion library, I recompile only that part of the OF source on my personal folder on the cluster. Indeed the src folder in my personal folder contains only the modified library. I'm sorry if I'm not able to be more clear, I'm not an expert and I followed only the hints I found on this forum. Anyway, thank you very much for your help! Federica |
October 10, 2016, 20:18 |
#4 | ||
Bruno Santos
Rep Power: 128 |
Quick answers:
Depending on the changes you've done, you might want to change the final name and location of the custom library. If you edit the file "Make/files" for this custom library and change the last line to use "FOAM_USER_LIBBIN" instead of "FOAM_LIBBIN" and if you use another name for the library, this way you can ensure that the original build of this library is not affected. Then don't forget to use the correct name in the dictionary files on the case. |
OpenFOAM on cluster: version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found | ovie | OpenFOAM | 10 | April 19, 2021 19:06 |
Divergent temperature in chtMultiRegion(Simple)Foam | akrasemann | OpenFOAM Running, Solving & CFD | 13 | March 24, 2014 03:54 |
Can we merge HPC Pack licenses? | Phillamon | FLUENT | 0 | January 24, 2014 03:59 |
OpenFOAM Patched Version 1.5 via git Repository | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | August 26, 2008 06:06 |
Version 12 speed compared to 11 | maka | OpenFOAM Running, Solving & CFD | 2 | December 21, 2005 06:42 |
