Sig Density Based Solver can not running in parallel |
September 29, 2016, 21:20 |
Janry
Rep Power: 11 |
Hi Foamers,
I'm trying to use SIG density based solver to simulate an transonic turbine problem. However, I've found that those solvers have no ways running in parallel. Thus if I have a large mesh grids, it will cause me a rather long period of time for reaching converging. Could any body have some experience in using those density based solvers and want to share with me? Thanks in advance! Janry |
Pressure based and Density based Solver | Xobile | Main CFD Forum | 39 | August 19, 2020 07:04 |
different results between serial solver and parallel solver | wlt_1985 | FLUENT | 11 | October 12, 2018 09:23 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 12:58 |
Using Density Gradient C_R_G(c,t), Pressure Based Solver | Anirudh_Deodhar | Fluent UDF and Scheme Programming | 1 | October 25, 2013 06:43 |
Pressure gradient in UDF for density based solver | matzb | FLUENT | 0 | February 22, 2010 07:34 |
