How to run the 3dTube case in parallel (foam-extend 3.1 with FSI from Zagreb)? |
September 26, 2016, 07:26 |
Lucas Ribeiro
Rep Power: 10 |
Hello guys!!
Does anybody know how to run the 3dTube case in parallel (foam-extend 3.1 with FSI from Zagreb)? Thanks Edit 1 (27-Set-2016): I managed to run and the bash script(it's my first draft) that I used is the following: File: AllcleanPar Code:
#!/bin/sh # Source tutorial clean functions . $WM_PROJECT_DIR/bin/tools/CleanFunctions cleanCase \rm -f constant/polyMesh/boundary \rm -rf history \rm -f constant/solid/polyMesh/boundary \rm -rf constant/solid/polyMesh/[c-z]* \rm -rf ../solid/VTK cd ../solid cleanCase # ----------------------------------------------------------------- end-of-file Code:
#!/bin/sh rmLinks () { rm 0/solid rm constant/solid rm system/solid } makeLinks () { cd system ln -s ../../solid/system solid cd ../constant ln -s ../../solid/constant solid cd ../0 ln -s ../../solid/0 solid cd .. } rmLinks makeLinks # Source tutorial run functions . $WM_PROJECT_DIR/bin/tools/RunFunctions # Get application name application=`getApplication` runApplication -l log.blockMesh.solid blockMesh -region solid runApplication -l log.setSet.solid setSet -case ../solid -batch ../solid/setBatch runApplication -l log.setToZones.solid setsToZones -case ../solid -noFlipMap runApplication blockMesh runApplication setSet -batch setBatch runApplication setsToZones -noFlipMap runApplication decomposeParFsi cd ../solid runApplication decomposeParFsi -case ../solid # ----------------------------------------------------------------- end-of-file Code:
#!/bin/bash for proc in processor* do cd $proc cd 0 ln -s ../../../solid/$proc/0 solid cd ../constant ln -s ../../../solid/$proc/constant solid cd ../.. done # ----------------------------------------------------------------- end-of-file Code:
#!/bin/sh # Source tutorial run functions . $WM_PROJECT_DIR/bin/tools/RunFunctions # Get application name application=`getApplication` #mpirun -np 8 $application -parallel > log.parallel & runParallel $application 8 #runApplication $application # ----------------------------------------------------------------- end-of-file Code:
$ reconstructParFsi -region solid $ reconstructParFsi Last edited by Warlord; September 27, 2016 at 07:30. Reason: Adding the answer |
January 27, 2018, 15:48 |
fsi parallel
Sam
Rep Power: 9 |
Hey men,
were you able to run your fsiFoam case in parallel? If yes, can you share how you did it? Thanks Samuel |
foam-extend 3.1, fsi |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 16:13 |
InterDyMFoam+simpleFunctionObject | Elham | OpenFOAM Running, Solving & CFD | 5 | July 10, 2017 12:59 |
damBreak case parallel run problem | behzad-cfd | OpenFOAM Running, Solving & CFD | 5 | August 2, 2015 18:18 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
Run in parallel a 2mesh case | cosimobianchini | OpenFOAM Running, Solving & CFD | 2 | January 11, 2007 07:33 |
