Standard InterDyMFoam doesn't work after modifying interFoam
Old   September 23, 2016, 06:21
Default Standard InterDyMFoam doesn't work after modifying interFoam
Helvines Aquino
nesca87 is on a distinguished road
Greetings to all FOAMers,
Recently, I tried to modified interFoam by adding temperature transport equation just like myinterfoamdiabatic by Qingming Liu with a few modification. http://www.tfd.chalmers.se/~hani/kur...ingmingLiu.pdf
I used user directory for both the new library and the new solver. The modified one works very well. However, when I tried to run the original interDyMFoam, the following error appeared:
PHP Code:
--> FOAM FATAL IO ERROR
keyword cp is undefined in dictionary "/home/hicha2/OpenFOAM/hicha2-2.3.0/run/tutorials/multiphase/interDyMFoam/ras/sloshingTank2D/constant/transportProperties.water"
file: /home/hicha2/OpenFOAM/hicha2-2.3.0/run/tutorials/multiphase/interDyMFoam/ras/sloshingTank2D/constant/transportProperties.water from line 22 to line 24.
    From
function dictionary::lookupEntry(const word&, boolbool) const
in file db/dictionary/dictionary.C at line 437.
FOAM exiting
I did copy interDyMFoam tutorial to the user run directory, though. But, before I modified the interFoam, interDyMFoam worked well even though I used user run directory for simulation. I think the problem was about a constant which I added in the modified interFoam source library (cp, as shown in the error message), but I can't prove it since in there isn't anything about the library written in the error message. I assume the interFoam affects interDyMFoam because in OF solvers directory they're in the same folder.
Is there anyone who has experienced this problem? How can we move back to the standard OpenFOAM source library directory, after using user source library directory of another solver?
I am a newbie with OF and I have already tried to google this problem, but there is no a good result.
I'm using OD 2.3.0 in Ubuntu 12.04. Any kind of help is very appreciated.
Thank you,
Hicha
nesca87 is offline   Reply With Quote
Old   September 23, 2016, 09:52
Bloerb will become famous soon enough
I think you made the following mistake. You compiled your new solver with the same name. You have basically overwritten your current solver
Inside make/files change
interFoam.C
EXE = $(FOAM_APPBIN)/interFoam
to
myInterFoam.C
EXE = $(FOAM_USER_APPBIN)/myInterFoam
Also rename your C file and compile the solver again. You can now call your solver by myInterFoam. Now recompile the standard interfoam solver.
Bloerb is offline   Reply With Quote
Old   September 23, 2016, 10:08
Helvines Aquino
hello Bloerb,
Thanks for your answer.
However, I don't have any problem with the new solver.
The failed one is the original version in OpenFoam-2.3.0 directory which I didn't do any changes. I used user-2.3.0 directory for the new solver.
Just now, I realized that not only interDyMFoam, the standard solver of interFoam doesn't work as well.
Old   September 23, 2016, 15:59
Yes and if you give your solver the same name that still applies. The easy way to check is to go inside your user directory ($FOAM_USER_APPBIN) and remove the solver. It should be in the platforms/..../bin folder. After that open a new terminal and check again.
Old   September 26, 2016, 07:26
Helvines Aquino
Both solver had different names. It seems because OF used user directory platform instead the main one which usually been used by the standard solvers.
I solved the problem by compile again the library in main directory and it kind of work for me.
Anyway, thank you for your kind answer. I wouldn't realize if you didn't mention about the platform directory in the user directory.
Old   January 5, 2017, 17:34
CFDlover
genshih is on a distinguished road
Hi Hicha,
Could you please elaborate a little more since i am also facing the same problem now.
Regards,
genshih is offline   Reply With Quote
Old   January 5, 2017, 17:35
CFDlover
Hi Hicha,
Regards,
Old   January 5, 2017, 23:47
Helvines Aquino
Hi genshih.
Would you tell me more detail of your problem?
reconstructPar does not work in interDyMFoam ageorg OpenFOAM Post-Processing 4 April 15, 2016 14:25
OF 2.0.0: Residual control does not work in interFoam LarsPT OpenFOAM Running, Solving & CFD 14 April 10, 2016 15:26
strange curvature with interFoam (comparison with Brackbill work) duongquaphim OpenFOAM Running, Solving & CFD 23 July 25, 2013 02:03
Does PISO algorithm work with interfoam in openFOAM 2.1.0? Krishna Sandeep OpenFOAM Running, Solving & CFD 3 June 14, 2012 02:32
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
