September 19, 2016, 02:15 |
Running reactingFoam in turbulence mode
chen king arthur
Rep Power: 10 |
Hi guys anyone knows how to run reactingFoam in tubulence mode? Please help anything needed to bedone besides changing the simulationType in turbulence properties?
September 25, 2016, 17:16 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: In principle, it should be possible to use turbulence in reactingFoam the same way as in the tutorial cases at "compressible/rhoPimpleFoam/".
Nonetheless, I have not tested this myself and it's possible that reactingFoam only supports a few turbulence models. In order to know which ones work, you can use this trick: http://openfoamwiki.net/index.php/Op...de/Use_bananas
Running Ansys in BAtch Mode | kuleuvenstudent | ANSYS | 1 | October 18, 2017 13:11 |
Les turbulence model in steady mode | shahrbanoo | FLUENT | 2 | April 18, 2016 12:00 |
Having problems running transient fluent simulation in batch mode | obylong | FLUENT | 1 | August 15, 2014 00:58 |
Running macros in parallel in batch mode | nomad | STAR-CCM+ | 13 | February 22, 2013 09:30 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 08:52 |
