foamMonitor in parallel processing
Old   September 15, 2016, 10:44
Default foamMonitor in parallel processing
Sharon
foamingMouth is on a distinguished road
I'd like to monitor my residuals on a simpleFoam project I am running using foamMonitor. I have followed section 6.3.4 "Live monitoring of data" from this tutorial: http://cfd.direct/openfoam/user-guid...hs-monitoring/
I can get it to work nicely if I run it for a small test case, but when I run my main project in parallel the postProcessing folder does not appear.
After meshing I have typed the following into the terminal:
$ decomposePar
$ mpirun -n 6 renumberMesh -overwrite -parallel
$ mpirun -np 6 simpleFoam -parallel >log &
Do I have to change something to account for running in parallel with the foamMonitor to track residuals? So far I copied the "controlDict" and "residuals" files from my test case.
Thanks!
foamingMouth is offline   Reply With Quote
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
problem for parallel processing minaret OpenFOAM Running, Solving & CFD 14 January 20, 2015 00:41
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 07:17
About parallel processing in Linux tuks CFX 10 August 8, 2005 09:22
