interFoam - unphysical behavior when filling tank
Old   September 15, 2016, 07:25
Default interFoam - unphysical behavior when filling tank
TommyCP is on a distinguished road
Dear fellow FOAMers, I’ve run into a problem with an interFoam simulation that I would like to request your help with.
I’m trying to simulate the filling of a tank with a high-viscosity liquid. The vessel has both the inlet and outlet placed on top. At the start, the vessel is filled half with air, half with liquid. The vessel is then filled with liquid until full.
The expectation of the simulation is that the vessel would be filled up almost completely with some air pockets remaining. However, it currently will not fill for more than 80-85 %. Once it is filled up this far, the liquid starts getting ‘sucked’ into the outlet in an unphysical way. Oddilly enough, it does not come into contact with the ceiling of the vessel nor with the walls of the outlet.
I’ve tried many things to create a more realistic behavior, all to no avail. Things I’ve tried:
Geometry-related:
- tilting the whole mesh at a very slight angle
- increasing the height of the outlet (see attached images)
Mesh-related:
- adding more/less layers on the walls
- increasing/decreasing mesh fineness
- using a more fine mesh only around the inlet and outlet
- note: checkMesh never reports any errors
transportProperties-related:
- varying sigma from 0.07 down to 0
BC-related:
- trying various boundary conditions for inlet, outlet, and walls (see below for current BCs), based on the capillaryRise and damBreak examples as well as various hints on these forums. To name a few of the important ones:
o for alpha: * inlet: inletOutlet; * walls: zeroGradient or constrantAlphaContactAngle (with various values for theta0); * outlet: inletOutlet or zeroGradient
o for p_rgh: * inlet: fixedFluxPressure; * walls: fixedFluxPressure or fixedValue; * outlet: fixedValue or totalPressure
o for U: * inlet: flowRateInletVelocity; * walls: fixedValue; * outlet: pressureInletOutletVelocity or zeroGradient.
Solver-related:
- trying interpolationSchemes ‘linear’ and ‘midPoint’
- trying divSchemes ‘Gauss limitedLinearV 1’ and ‘Gauss upwind’ for div(rhoPhi,U)
- trying divSchemes ‘Gauss linear’ and ‘Gauss interfaceCompression’ for div(phirb,alpha)
- playing with nAlphacorr, nAlphaSubCycles, cAlpha
- enabling/disabling the momentumPredictor
- reducing maxCo from 0.95 to 0.2
Currently, I’m at a loss so I would like to ask if anyone has an idea how to get more realistic results. Below are some of the settings I last used. I also attached a few screenshots of the simulation. Thank you for any help you can provide!
alpha
internalField   uniform 0;
  boundaryField
      inlet
          type            inletOutlet;
          inletValue      uniform 1;
          value           uniform 1;
      main
          type            constantAlphaContactAngle;
          theta0          45;
          limit           gradient;
          value           nonuniform 0;
      outlet
          type            inletOutlet;
          inletValue      uniform 0;
          value           uniform 0;
p_rgh
  boundaryField
      inlet
          type            fixedFluxPressure;
          value           uniform 0;
      main
          value           uniform 0;
      outlet
          type            totalPressure;
              p0          uniform 0;
              U           U;
              phi         phi;
              rho         rho;
              psi         none;
              gamma       1;
              value       uniform 0;
U
internalField   uniform (0 0 0);
  boundaryField
      inlet
          type            flowRateInletVelocity;
          massFlowRate    constant 0.1;
          value           uniform (0 0 -0.1);
      main
          type            fixedValue;
          value           uniform (0 0 0);
      outlet
          type            zeroGradient;
fvSolution
solvers
      alpha.water
          nAlphaCorr      1;
          nAlphaSubCycles 2;
          cAlpha          1;
      pcorr
          solver          PCG;
          preconditioner  DIC;
          tolerance       1e-10;
          relTol          0.01;
      p_rgh
          solver          GAMG;
          smoother        GaussSeidel
          tolerance       1e-07;
          relTol          0.05;
      p_rghFinal
          $p_rgh;
          tolerance       1e-08;
          relTol          0.01;
      U
          solver          smoothSolver;
          smoother        symGaussSeidel;
          tolerance       1e-06;
          relTol          0;
      UFinal
          $U;
          tolerance       1e-08;
          relTol          0;
  PIMPLE
      momentumPredictor no;
      nCorrectors     3;
      nOuterCorrectors   1;
      nNonOrthogonalCorrectors 0;
fvSchemes
ddtSchemes
      default            Euler;
  gradSchemes
      default         Gauss linear;
  divSchemes
      div(rhoPhi,U) Gauss limitedLinearV 1;
      div(phi,alpha) Gauss vanLeer;
      div(phirb,alpha) Gauss interfaceCompression;
      div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
  laplacianSchemes
      default         Gauss linear corrected;
      default         midPoint;
  snGradSchemes
      default         corrected;
  fluxRequired
      default         no;
      p_rgh;
      pcorr;
      alpha;
controlDict
application     interFoam;
  startFrom       startTime;
  startTime       0;
  stopAt          endTime;
  endTime         125;
  deltaT          2e-3;
  adjustTimeStep  yes;
  writeControl    adjustableRunTime;
  writeInterval   5;
  purgeWrite      0;
  writeFormat     ascii;
  writePrecision  6;
  writeCompression uncompressed;
  timeFormat      general;
  timePrecision   6;
  runTimeModifiable yes;
  adjustTimeStep  yes;
  maxCo           0.95;
  maxAlphaCo      0.95;
  maxDeltaT       1;
TommyCP is offline   Reply With Quote
Old   September 26, 2016, 04:24
I've done some additional experimentation with my case. Using water (instead of the viscous liquid used earlier) did not lead to better results -- again, the liquid phase got 'sucked' into the outlet in an unphysical way. I'm currently running out of ideas on how to get a more realistic behavior.
If anyone has any ideas on this, I'd really appreciate it!
Old   September 26, 2016, 05:14
TobM is on a distinguished road
Try to use pressureInletOutletValocity BC on outlet (refer to point 5.2.3.2 in the user guide).
Use "normal" schemes as in damBreak or so.
Your mesh seems pretty coarse at the outlet, only 10 or so cells is not enough.
TobM is offline   Reply With Quote
Old   October 5, 2016, 05:28
Thank you for your suggestion. I've increased mesh fineness 2x in general and 4x around the inlet and outlet. Also, I changed my schemes back to those used in the damBreak example. Unfortunately, it did not change the behavior of my system. As for pressureInletOutletVelocity, I was already using this on the outlet.
My current BCs are as follows:
alpha
- inlet: inletOutlet
- outlet: inletOutlet
- wall: constantAlphaContactAngle
p_rgh
- inlet: fixedFluxPressure
- outlet: totalPressure
- wall: fixedFluxPressure
U
- inlet: flowRateInletVelocity
- outlet: pressureInletOutletVelocity
- wall: fixedValue
If you have any further suggestions, I'd much appreciate it.
Edit: just upgraded to OpenFOAM 4.0. Will try the new noSlip BC in U and make some changes to fvSolution.
Last edited by TommyCP; October 5, 2016 at 07:52. Reason: copy-pase error in listing p_rgh boundary conditions
Old   October 5, 2016, 05:41
You haven't read the user guide .
pressureInletOutletVelocity for U is used together with totalPressure for p_rgh
Old   October 5, 2016, 07:53
Sorry, that is an error in my post. I do indeed use totalPressure for p_rgh and pressureInletOutletVelocity for U.
Old   October 5, 2016, 08:10
Please compare your entire settings with settings from a similar tutorial, and check if your mesh is ok --> checkMesh.
Old   October 6, 2016, 04:25
Meshes always check out OK with checkMesh. I'm currently testing my case with settings taken from the angledDuct tutorial. I will let you know how it works out.
Thank you for your suggestions thus far.
Old   October 14, 2016, 04:40
Update: settings from the angledDuct tutorial result in a more physically correct behavior. Unfortunately, the case blows up when the tank is around 85 % full. I've found no way to avoid this.
I think it's time to give up and move. I've been trying to a lot of things to make this works, but apparently there's more to this seemingly simple case than meets the eye.
Again, thank you for your help.
Old   February 4, 2020, 09:07
Munaf
mwmalkawi is on a distinguished road
Hi Tommy
Have yo umnaged to find the soluiton fo your problem
Thakns
mwmalkawi is offline   Reply With Quote
interFoam / bubbleFoam to simulate an aerated tank Meratb OpenFOAM Running, Solving & CFD 3 November 6, 2020 12:45
Filling Tank with Water leff CFX 7 August 21, 2017 08:47
Filling of empty tank using interFoam behcfd OpenFOAM Running, Solving & CFD 11 August 21, 2017 08:20
tank filling (water/air), I think I messed up the BCs simpomann OpenFOAM Running, Solving & CFD 2 August 21, 2017 08:16
Air tank filling gsr_132 FLUENT 1 June 10, 2016 04:16
