September 14, 2016, 23:57 |
Aerospike making me aero-confused!
Anonymouse
Rep Power: 11 |
Hi all! I'm working on simulating an aerospike here with sonicFoam, and am quite happy to have finally gotten it to run stably rather than crashing out with negative temperatures (the solution for anyone reading: drop your p tolerance by a couple orders of magnitude). However.... now I'm confused by the results I'm seeing
(Note about the model: since it's an annular aerospike, its modeled as a wedge; the left-hand side is the center of the aerospike, aka a thickness of zero) First the velocity: All well and good. We have a jet of superhot (>5000K) gas moving at the speed of sound in the gas mixture (1300m/s) leaving the throat (the little angled bit at the bottom-center) in that direction, you expect to see things get moving! But pressure and temperature, however... How can it possibly be 5569 degrees at that port, yet ambient temperature everywhere else? Likewise: It's leaving that port at 100 atmospheres.... but then is immediately down to zero? And what's up with that thing on the left? That should be the *lowest pressure* place! :Þ I plan to try making the model "cleaner" to see if that helps any... but as it stands I'm a bit baffled. Thoughts on what might be going on? I'm attaching the blockMeshDict, p, U, and T files it's run with in case that helps. A summary: blockMeshDict: top (what shows up as the bottom on the screen): patch bottom (what shows up as the top): patch far (wedge wall): wedge near (the opposite wedge wall): wedge inner (zero-area left-side of the screen, center of the engine): symmetryPlane circumference (the right-hand edge): patch rocket_inner (all of the parts that are not actively spewing gas): wall engine (the part that is spewing gas): patch p: top: fixedValue, ~100kPa bottom: waveTransmissive far: wedge near: wedge inner: symmetryPlane circumference: waveTransmissive rocket_inner: zeroGradient engine: fixedValue, ~10 MPa defaultFaces: empty T: top: fixedValue, 300K bottom: zeroGradient far: wedge near: wedge inner: symmetryPlane circumference: zeroGradient rocket_inner: zeroGradient engine: fixedValue, 5569K defaultFaces: empty U: top: fixedValue, (0,0,0) bottom: zeroGradient far: wedge near: wedge inner: symmetryPlane circumference:zeroGradient rocket_inner: fixedValue, (0,0,0) engine: fixedValue, uniform (-650, 1125, 0) defaultFaces: empty |
September 18, 2016, 17:58 |
Anonymouse
Rep Power: 11 |
Solution was to decrease the tolerances in fvSolution.
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 04:04 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 14:59 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
