OpenFoam Parallel run on in docker container
Old   September 8, 2016, 15:54
Default OpenFoam Parallel run on in docker container
Yeru
shang is on a distinguished road
Dear all,
I am trying to run OF240's channel 395 LES parallel case in Docker container. I had enough nodes (4), it decomposed successfully, but when running, it showed following error message:
[PHP][f218acb175c7:00233] [[INVALID],INVALID] ORTE_ERROR_LOG: Not found in file ess_h
np_module.c at line 170
It looks like orte_init failed for some reason; your parallel process is
likely to abort. There are many reasons that a parallel process can
fail during orte_init; some of which are due to configuration or
environment problems. This failure appears to be an internal failure;
here's some additional information (which may only be relevant to an
Open MPI developer):
orte_plm_base_select failed
--> Returned value Not found (-13) instead of ORTE_SUCCESS
[f218acb175c7:00233] [[INVALID],INVALID] ORTE_ERROR_LOG: Not found in file runti
me/orte_init.c at line 128
orte_ess_set_name failed
[f218acb175c7:00233] [[INVALID],INVALID] ORTE_ERROR_LOG: Not found in file orter
un.c at line 69[/CODE]4
Does anybody have any clue to solve this problem?
Many thanks,
Yeru
PS: Apology for not being able to setting the format of the error message...
shang is offline   Reply With Quote
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 13:40
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 12:20
Problem in parallel run with OpenFOAM Gitesh P OpenFOAM Running, Solving & CFD 2 June 1, 2014 07:05
Parallel run of OpenFOAM in linux and windows side by side m2montazari OpenFOAM Running, Solving & CFD 5 June 24, 2011 04:26
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 13:08
