September 7, 2016, 16:52 |
DPM+Multiphase+InterFoam
Rep Power: 13 |
Recently coupled DPM with multiphaseInterFoam. The simulation is revised from damBreak4phase. The particle released from the left wall.
The results seem reasonable. The particle concentrated in water and the surface of oil. Due to the density of particle is less than mercury, some of the particle float at the top of mercury. The figure shows the simulations.DPMfourphase.jpg |
November 1, 2017, 09:08 |
Rep Power: 9 |
Heyho,
Can you explain how you made the coupling with DPM exactly? |
November 2, 2017, 16:27 |
Rep Power: 13 |
The whole frame is Eulerian-Lagrangian. VOF is based on Eulerian N-S equation with Weller VOF governing equation. DPM is used to describe Lagrangian moving equation.
The VOF was solved by MULES. |
January 16, 2019, 01:46 |
govind
Rep Power: 8 |
Can you please give me some suggestions to do this? I am working on fluid-particle interactions. Kindly help me. With regards, Govind Sharma |
multiphase explicitsolve function in interFoam | abdo1984 | OpenFOAM Programming & Development | 0 | September 4, 2016 11:26 |
multiphase explicitsolve function in interFoam | abdo1984 | OpenFOAM Running, Solving & CFD | 0 | September 4, 2016 05:45 |
k-e & GAMG interFoam Schemitisation Stability Issue | JFM | OpenFOAM Running, Solving & CFD | 3 | December 1, 2015 05:58 |
DPM or MultiPhase - Criteria - Help | jpinho | FLUENT | 2 | January 18, 2010 11:55 |
InterFoam wall boundary multiphase | RBJ | OpenFOAM Bugs | 2 | December 3, 2009 05:00 |
