Pipe flow simulation problem with pisoFoam: not getting parabolic profile
Old   September 7, 2016, 13:21
Default Pipe flow simulation problem with pisoFoam: not getting parabolic profile
Sheikh Ahmed
sahmed is on a distinguished road
Dear Foamers
I am trying to simulate a simple 3D pipe flow with a wedge-shaped geometry using pisoFoam>ras>cavity solver. The reason I am using piso, not ico is that, I have to use another solver with chemical kinetics which uses Piso as its base flow solver. My flow is laminar with an inlet velocity of 0.1384 m/s, tube length 355mm, tube radius 42mm with a slanted part at the inlet (the geometry with the boundaries mentioned is attached with this post). Since my flow is laminar, in the constant>RASProperties.RASModel, I put 'laminar' with unchanged turbulenceProperties and transportProperties-
RASProperties:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object RASProperties;
RASModel laminar; //kEpsilon;
turbulence off;
printCoeffs off;
turbulenceProperties:
FoamFile
version 2.0;
format ascii;
class dictionary;
object turbulenceProperties;
simulationType RASModel;
transportProperties:
transportModel Newtonian;
nu nu [ 0 2 -1 0 0 0 0 ] 1e-05;
CrossPowerLawCoeffs
nu0 nu0 [ 0 2 -1 0 0 0 0 ] 1e-06;
nuInf nuInf [ 0 2 -1 0 0 0 0 ] 1e-06;
m m [ 0 0 1 0 0 0 0 ] 1;
n n [ 0 0 0 0 0 0 0 ] 1;
BirdCarreauCoeffs
k k [ 0 0 1 0 0 0 0 ] 0;
Since I dont have turbulence, I didnt change any value of epsilon, k, nut and nuTilda in the 0 folder and I just put my pressure (P/rho) and velocity conditions-
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 85654.5;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 85654.5;
frontwall
type zeroGradient;
outerwall
type zeroGradient;
axisym_f1
type wedge;
axisym_f2
type wedge;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0.01311 0 0);
boundaryField
inlet
type fixedValue;
value uniform (0.138475 0 0);
outlet
type zeroGradient;
frontwall
type fixedValue;
value uniform (0 0 0);
outerwall
type fixedValue;
axisym_f1
type wedge;
axisym_f2
type wedge;
My problem is, I am not getting a parabolic profile even after running for a longer time and the jet from the inlet is not breaking rather it is moving forward on and on. The recirculation bubble is also moving/stretching with the flow. This is definitely wrong.
Do you have any idea why this is happening? PLEASE share any of your experience of suggestion.
Thanks in advance
sahmed is offline   Reply With Quote
Old   September 7, 2016, 15:00
Sheikh Ahmed
Any of your suggestion will be highly appreciated. Please share if you faced similar problems.
~SFA
jet breakup, laminar flow, pipe flow, pisofoam, wedge type
Pipe Flow Simulation comingdaytime OpenFOAM Running, Solving & CFD 3 July 27, 2016 11:40
[swak4Foam] problem with a parabolic velocity profile Claudio87 OpenFOAM Community Contributions 5 May 29, 2014 10:30
problem in slug flow simulation abdoganawa Main CFD Forum 0 March 17, 2013 11:35
Strange velocity profile at the inlet for a flow inside a cylindrical pipe michmich OpenFOAM Running, Solving & CFD 0 July 2, 2012 04:37
Parabolic Velocity Profile In 3 D Pipe FLow abhimanyu_wit FLUENT 5 January 28, 2012 04:39
