Mass transfer of bubbles in liquid with reactingTwoPhaseFoam |
September 7, 2016, 08:24 |
Mass transfer of bubbles in liquid with reactingTwoPhaseEulerFoam
Andreas
Rep Power: 17 |
we want to investigate the mass transfer between bubbles and the surrounding liquid for a bubble column type set-up. We plan to use the reactingTwoPhaseEulerFoam solver which has - for my understanding - all necessary models. 1) Is there any kind of documentation available for that solver and the setup I could read? 2) I have some questions on the phaseProperties file, maybe some can help me 2.1)What is the meaning of these kind of lines? Code:
minFullyContinuousAlpha.gas 0.7; minPartlyContinuousAlpha.gas 0.5; minFullyContinuousAlpha.liquid 0.7; minPartlyContinuousAlpha.liquid 0.5; 2.3) In the bubbleColumnEvaporatingDissolving\constant\phasePr operties file is the following definition: Code:
interfaceComposition ( (gas in liquid) { type Saturated; species ( water ); Le 1.0; saturationPressure { type ArdenBuck; } } (liquid in gas) { type Henry; species ( air ); k ( 1.492e-2 ); Le 1.0; } ); Thanks for your help. Best regards Andreas Last edited by erklaerbaer; September 8, 2016 at 07:10. |
May 31, 2018, 19:51 |
#2 | |
Noah Yao
Rep Power: 9 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Specify mass transfer source term at gas liquid interface | SAM S | Fluent UDF and Scheme Programming | 4 | January 21, 2016 07:23 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
liquid phase reactions and mass transfer | Swarup | FLUENT | 0 | January 17, 2005 00:47 |
