MRFSimpleFoam - Influence of Solver Settings
Old   August 30, 2016, 04:02
Default MRFSimpleFoam - Influence of Solver Settings
schneiderj is on a distinguished road
Hi there,
I was just doing the axialTurbine_mixingPlane tutorial for the MRFSimpleFoam solver (foamExtend 3.2) and found out that the final result (eg. total pressure loss and torque on the runner blade) is very sensitive not only to the interplotation schemes but also to the relaxation factors. If I increase the relaxation for velocity the torque increases.
Besides, the residuals of the tangential velocity always remain on a high level and I can't push them down.
Does anyone have experience using the MRFSimpleFoam solver and maybe had the same problems?
I would appreciate any hints!
Best regards,
Julian
schneiderj is offline   Reply With Quote
axialturbine tutorial, mixing plane, mrfsimplefoam, relaxation factor, solver settings
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
[ANSYS Meshing] Bodies of Influence Settings / Problem cycleodyssey ANSYS Meshing & Geometry 1 January 11, 2012 17:57
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
solver settings, residuals plateau for a long time Mumawalde CFX 2 December 17, 2007 09:49
