August 25, 2016, 02:05 |
Erro during run the solver..
mohd nor hazwan bin hadzir
Rep Power: 10 |
Hai all, im Hazwan, im new in OpenFoam usage,
i got some problem during im running the solver in MHD.. anybody have involve in this kind of problem?? Courant Number mean: 18740.4 max: 2.49723e+06 smoothSolver: Solving for Ux, Initial residual = 0.670023, Final residual = 9.80478e-06, No Iterations 193 smoothSolver: Solving for Uy, Initial residual = 0.846497, Final residual = 9.9397e-06, No Iterations 70 DICPCG: Solving for p, Initial residual = 0.988061, Final residual = 7.26658e-07, No Iterations 392 time step continuity errors : sum local = 0.0726019, global = -0.00074038, cumulative = -0.000826256 DICPCG: Solving for p, Initial residual = 0.28924, Final residual = 4.96783e-07, No Iterations 391 time step continuity errors : sum local = 0.0742087, global = 0.00076225, cumulative = -6.40061e-05 DICPCG: Solving for p, Initial residual = 0.205221, Final residual = 3.70875e-07, No Iterations 391 time step continuity errors : sum local = 0.0385866, global = 0.000402648, cumulative = 0.000338642 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 ? at ??:? #7 ? at ??:? #8 ? at ??:? #9 ? at ??:? #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 ? at ??:? Floating point exception (core dumped) |
August 28, 2016, 23:47 |
Courant number
Maryam
Rep Power: 10 |
Change your time step to make sure that your Courant number stays below 1.
courant number, mhdfoam |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
Pinning the processors in cluster to run a solver | coolcrasher | OpenFOAM Running, Solving & CFD | 0 | November 5, 2015 07:11 |
new Solver won't run parallel | Chris Lucas | OpenFOAM | 4 | January 10, 2012 11:30 |
HOW can I run a solver without installatiom | waynezw0618 | OpenFOAM Installation | 1 | December 12, 2007 01:39 |
Help, can't stop solver run...Windows OS | ben akih | CFX | 2 | November 13, 2006 11:05 |
