running interFoam on unstructured mixed elements |
August 19, 2016, 06:57 |
AndreiCFD
Rep Power: 13 |
Dear All,
I am trying to run interFoam on a mesh with unstructured mixed elements. I've also created a hex mesh of the same geometry. The thing is that interFoam runs on hex meshes but not on unstructured mixed meshes. Has anyone seen a similar behaviour? Any suggestions are appreciated. Thanks, Andrei |
August 19, 2016, 08:37 |
Rep Power: 12 |
Can you give more information about your cases?
Outputs of checkMesh for both meshes would be nice. And what exactly do you mean with "not running"? Does it fail to start the simulation? Does it diverge? --> log files are needed Especially the interFoam solvers are very very picky about cell orthogonality. |
August 22, 2016, 04:40 |
AndreiCFD
Rep Power: 13 |
Hi TobM! Thanks for replying. I've attached the test case. I am interested to apply FOAM on much more complex geometries. This is just a simple box with mixed elements. The test case is located
https://www.dropbox.com/s/oq46ckf9ey..._test.zip?dl=0 Any suggestions are welcomed. Have a great day and thank you. Regards, Andrei |
[ICEM] Hybrid mesh for 2D boundary layer | Bigio | ANSYS Meshing & Geometry | 33 | November 18, 2019 10:15 |
[ICEM] Converting to unstructured mesh | lcaBR | ANSYS Meshing & Geometry | 0 | April 16, 2014 19:06 |
unstructured mesh | phoenics user | Phoenics | 26 | March 22, 2012 13:17 |
Unstructured Grid using InterFoam | Andrea_85 | OpenFOAM | 4 | February 4, 2011 06:01 |
structured and unstructured grids | user | Main CFD Forum | 6 | November 25, 2010 02:14 |
