adsorption/desorption simulation of volatile organic compound |
Ali reza
Rep Power: 12 ![]() |
Hi all
I want to simulate adsorption/desorption of benzene on the activated carbon fiber under dynamic conditions with OpenFOAM. I have a channel which is filled with adsorbants (small carbon spheres) and air(with pollutants) flows through this channel. I want to simulate the amount of pollutants which is adsorbed and so on. Is there any solver in OpenFOAM for this purpose? + I have found some posts about adsorption process in catalytic surface reactions but still I do not know which solver should I use. http://www.catalyticfoam.polimi.it/ http://www.detchem.com/ As I have never used these solvers I have no idea if I can use them in my problem. Thank you |
Ali reza
any idea?!
Luckmore Kadzungura
Rep Power: 5 ![]() |
Hie, i just need to know if you managed to solve your problem?
adsorption/desorption |
Waterbell Simulation | o.b.m | Fluent Multiphase | 1 | November 5, 2015 05:55 |
mass flow rate issue in supersonic nozzle simulation | xkang | FLUENT | 0 | July 31, 2014 16:06 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 14:29 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
