Accuracy of LRR and SSG in turbulent channel flow
Old   August 16, 2016, 15:25
Default Accuracy of LRR and SSG in turbulent channel flow
Darko Radenkovic
dradenkovic is on a distinguished road
Hello.
I am simulating steady, incompressible flow in channel. Dimensions of channel are:
length 6 m, width 350 mm, and height 35 mm.
I did simulations with two RSMs - LRR and SSG. When I compare results of simulations with experimental and DNS data, I see that accuracy of simulations can be improved. Measuring section is at 5.8 m from the inlet.
Figures are on the following links (from some reason, I couldn't attach pictures on this page)
LRR comparison
Here is comparison for SSG simulation:
SSG comparison
I don't have exact DNS data for this case, but I used data for channel flow where Re number is around 40 000 so I believe it can be used for verification, when data are nondimensionalised.
Information about setup are here:
CheckMesh
fvSchemes
fvSolution
Any suggestion to improve accuracy of these simulations?
Best regards,
Darko
dradenkovic is offline   Reply With Quote
Old   August 23, 2016, 14:03
Darko Radenkovic
Here are velocity profiles that I have as a result of a several simulations.
https://www.dropbox.com/s/eyd4tk3rid...Phase.eps?dl=0
I have error around 5% in velocity profile. What can I do to reduce it? I did simulations on various meshes, but the result is the same.
I have trouble to verify RMS values (from above post). Maybe that difference in RMS values (which is causing me troubles) is due to difference in velocity profiles. That is why I need to correct velocity profile.
Here is complete case of steady, incompressible, turbulent channel flow, k - epsilon model.
https://www.dropbox.com/s/z1w7bu9mv1...imple.zip?dl=0
Any suggestion is appreciated.
Best regards,
Darko
