Iddes
Old   August 15, 2016, 07:51
Default Iddes
ali alkebsi
kebsiali is on a distinguished road
Hello Dear foamers
I'm modelling flow inside a wind tunnel "a real experimental wind tunnel"
The wind tunnel has a devised geometry to generate a huge recirculation bubble.
I had the geometry meshed and ran using Spallart-Allmaras turbulence model it converged in simpleFoam and then i ran it in pisoFoam for around 20seconds of physical time but the physics sought is not seen due to the lacking of an LES or DNS abilities.
I jumped into using IDDES models either Spallart-Allmaras IDDES in OF3 or 4 or k-omega SST-IDDES in OF3+ or 1606+
I dont know if these models have been validated yet or not
and it is because of this that I'm here
when I run my simulation using the IDDES models the calculation diverges
I've tried piso and pimple, backward and crankNicolson 0.9, tried to increase nCorr, nOuterCorr, nNonOrthCorr, but it doesnt improve
Im using the LUST scheme for the div(phi,U), tried to play with the solver parameter forcing lower tol and relTol increasing the sweeps of the GAMG p solver without success
What I notice is big vortices being generated downstream of the main recirculation.
I have tried a full 3d case and an extruded 2d case (2.5d) but have the same problems.
any ideas please???
kebsiali is offline   Reply With Quote
Problems with IDDES in openfoam2.1.1 Joanna Huang OpenFOAM Running, Solving & CFD 21 August 22, 2022 08:50
Anyone using IDDES cfdmarkus OpenFOAM Running, Solving & CFD 18 June 19, 2021 05:06
Smoothing of IDDES delta Fuchs OpenFOAM Running, Solving & CFD 2 November 17, 2020 12:17
IDDES in OF2.4 for Sphere on incompressible flow aerospain OpenFOAM Running, Solving & CFD 0 April 1, 2016 19:23
Alpha in IDDES tookey_1989 OpenFOAM 1 July 3, 2012 06:44
