August 8, 2016, 06:45 |
problem stabilizing kw-sst..
Anonymous
Rep Power: 10 |
Hi everyone,
I am encountering a strange problem while using kw-sst turbulence model in case of a 3d airfoil. In a very few steps omega and k both stop iterating (No of iterations = 0) and they seem to be converged, residuals being as low as 10^-15... I am using 10^-08 tolerance in the solver and 10^-04 as relTol... What could be the reason behind this behaviour? Any help is appreciated.. |
August 8, 2016, 07:30 |
Hyoung Min Suh
Rep Power: 10 |
What is the y+ value?
August 8, 2016, 08:05 |
Anonymous
Rep Power: 10 |
Yplus is 300
August 8, 2016, 15:45 |
Mahdi Hosseinali
Rep Power: 18 |
I think your yplus is out of the log layer. What is your boundary conditions for the airfoil?
Also you gotta check which variable goes unstable first? Other than that, you can try outputting your results more frequent and visually check what is going wrong? works more than you think. |
August 8, 2016, 16:25 |
Anonymous
thanks, i will try doing these first to see if i get it working...
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 11 | September 4, 2024 05:28 |
General question about SST turbulence model | Richard Renaud | CFD Freelancers | 1 | December 19, 2015 05:13 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 05:43 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 09:39 |
2D SST Simulation Airfoil - Convergence Problem | Kraemer | CFX | 10 | April 16, 2011 08:22 |
